copperhead 12 bushing
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=31485
Author:  grasshopper [ Mon Aug 13, 2012 6:16 pm ]
Post subject:  copperhead 12 bushing
Ok my shaft has a rattling sound and there is a little play up and down .. not any noticeable side to side .. is that normal wear .. it looks fairly simple to repair .. is it ? Any tricks I need to know ?
Author:  garrettpearce [ Tue Aug 14, 2012 7:13 am ]
Post subject:  Re: copperhead 12 bushing
Normal for a copperhead. It'll happen time and time again
Author:  cmiller73 [ Tue Aug 14, 2012 10:59 am ]
Grease the crap out of it. And make sure you grease it before every outing. It will save on the wear of the bushing.
Author:  grasshopper [ Tue Aug 14, 2012 11:14 am ]
Is there any trouble in replacing it .. a friend of mine jade a machine shop what about one made of teflon .. we use bushing at work made of this.. they last for ever even ware down stainless steel
Author:  scott0227 [ Wed Aug 15, 2012 5:57 pm ]
Its not bad but, the hub is screwed to the shaft housing with reverse threads. It also has red loctite so it needs to be heated. The gear for the belt at the rear of the prop shaft comes of easy with a light impact with allen head adapter. Use the prop shaft to tap out the bushing. I like the idea u got for the bushing. let us know if it works.
Author:  scott0227 [ Wed Aug 15, 2012 6:01 pm ]
Also I think you can over grease it and blow out the prop shaft seal.
Author:  grasshopper [ Wed Aug 15, 2012 7:33 pm ]
Oh snap .. I have to take the shaft off ... Is the bushing that tight ? I think I can get it off without pulling lower unit apart ... Has anyone tried to pull bushing without dis assembling shaft ... Only thing I'm worried about on teflon bushing is high revaluation... We use em in a lot lower rpms ...
Author:  grasshopper [ Wed Aug 15, 2012 7:44 pm ]
I bought this motor used ... Don't have any experience with them .. I'm a decent mech. Tho ... So help is very much need
Author:  scott0227 [ Thu Aug 16, 2012 4:40 pm ]
You can remove the prop shaft seal but not the brass bushing. It needs to be tapped out a little bit all the way around till its out.
Author:  cmiller73 [ Fri Aug 17, 2012 7:20 am ]
If you have questions, call Gil at Copperhead. He'll tell you what you need to do to get it fixed.
Author:  grasshopper [ Fri Aug 17, 2012 4:31 pm ]
I will call gil .. ment 2 today but working a shut down no time to
