It is currently Thu Dec 18, 2025 6:22 am
[ 3 posts ] |
brock2013
Joined: Sun Aug 12, 2012 1:04 pm Posts: 35 Location: Brock TX
 Shaft housing
Where do you get shaft housings? Or do you make them yourselfs? How do you make the housing so the bearings fit?
| Mon Aug 20, 2012 10:43 pm |
Sgt Griz
Joined: Sun Aug 12, 2012 8:55 pm Posts: 3 Location: Minnesota
 Re: Shaft housing
Made it 1 1/4 DOM tube three brass bushings 1 in OD 3/4 in ID may have to sand down the out side a little so the fit but not to much drill and tap your tube in the center and 2.5 in from the ends two holes per bushing I taped mine in 1/4 28 place your brass with a wood dowell seals came from carquest again 1 in OD 3/4 in ID your set screws for your bushings should be about 45 degrees apart drill and tap two extra holes for your grease nipples drill and t tap all holes before placing brass
_________________ You can't fix stupid but you can at least try and cut it off at the pass
| Tue Aug 21, 2012 1:13 am |
brock2013
 Re: Shaft housing
Do you have any pictures of it?
| Wed Aug 22, 2012 9:01 pm |
[ 3 posts ] |
