tailfisher17t
 GDSD Gear Ratio
Are you able to change out the gear ratio in a GDSD for make the prop spin faster??
_________________ Team Total ASalt Mossy Oak Pro Staff 1854Gator Traxs w/HD pushed by a MB 5000. Ams wrote: If assholes could fly this place would be an airport
| Wed Apr 10, 2013 4:11 pm |
CCC
 Re: GDSD Gear Ratio
Yep
| Wed Apr 10, 2013 5:13 pm |
tailfisher17t
 Re: GDSD Gear Ratio
Do tell .......
| Wed Apr 10, 2013 5:44 pm |
Gigafowl
 Re: GDSD Gear Ratio
You have a 1.4 to 1 reduction on a stock 35 GDSD.... You must also factor in prop pitch to get true "final gearing" !!! The motor pulley has less teeth than the lower shaft pulley so for every 1.4 motor revolutions you have 1 prop revolution... The 27 GDSD has 1.5 to 1 and the 23 GDSD has 1.7 to 1 reduction so that they all can turn the same 11" 3 blade prop.... The GDSD prop and the PD are both 12 pitch - MB and GT use a 10 pitch and less reduction... Hopkins will build you any pitch you like and that is easier than a pulley change... More info on this thread... viewtopic.php?f=3&t=20486&p=382758&hilit=ratio#p382758
| Wed Apr 10, 2013 6:17 pm |
tailfisher17t
 Re: GDSD Gear Ratio
Thank you Sir, Right now I am hitting 30mph on the GPS at 4k with the prop deep in the water. If I trim it up it blows it out and hits the rev limit. The boat is a Custom 16.6/48 open plan with a hunt deck (that I want to trade or sale for a GD or GTraxs.) It has a 2 blade on it now and I am not sure if its very worn or not. Would a stock 3 blade hook better and I would go a little faster?
I am happy with the speeds just that it blows out if I trim it higher.
| Thu Apr 11, 2013 8:26 am |
tailfisher17t
 Re: GDSD Gear Ratio
| Thu Apr 11, 2013 8:27 am |
tailfisher17t
 Re: GDSD Gear Ratio
Sorry for the double post, not sure what happened....
| Thu Apr 11, 2013 8:28 am |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
 Re: GDSD Gear Ratio
I say don't do it. I had mine stage 2 modded and thought about it, but in the end you would rather have grunt than top speed. If you are stock you will suck in the mud. My .02 cents.
| Thu Apr 11, 2013 11:54 am |
AKA Freshwaterkilla
 Re: GDSD Gear Ratio
| Thu Apr 11, 2013 12:12 pm |
tailfisher17t
 Re: GDSD Gear Ratio
Its a modded motor. I think the prop is worn so I am going to order a 3 blade but still 30mph is pretty freaking fast at 4K rpms. When I trim it to where it "should" be with a little rooster tail it hits the rev limiter mainly due to prop slippage in the water. (cup appears to be going/gone.) I got the motor now I just need a bigger boat!
| Thu Apr 11, 2013 12:28 pm |
tailfisher17t
 Re: GDSD Gear Ratio
O I dont run shallow water often and there's not much mud here on the gulf coast. I do have to cross shallow water to get to some deep areas and mostly hunt deep but topped out hydrilla lakes.
| Thu Apr 11, 2013 12:30 pm |
duckmedic269
 Re: GDSD Gear Ratio
damnnnnn i told you it would hit 30 lol....
| Thu Apr 11, 2013 1:18 pm |
duckmedic269
 Re: GDSD Gear Ratio
and im with robin .. you want that ass to get you unstuck , save for the three blade and use the 2 as a spare
| Thu Apr 11, 2013 1:20 pm |
tailfisher17t
 Re: GDSD Gear Ratio
Will do!! Yeah its pretty dang fast!! I am sure it would go 32 if I could get it to bite more. It runs great at 4k trim it up a little and WOT it blows it out! its like a half turn from 4k to 4500!!
Love the motor!!
| Thu Apr 11, 2013 1:48 pm |
Robn1020
 Re: GDSD Gear Ratio
| Thu Apr 11, 2013 2:06 pm |
bobbyjober
Joined: Sun Aug 08, 2010 3:28 pm Posts: 546 Location: St. Martinville, La
 Re: GDSD Gear Ratio
http://www.ebay.com/itm/12-X-12-7-8-Sha ... 232679ebc2Here is a 12x12 for you and price is affordable. There also are other pitches in 7/8 threaded.
_________________ 1542 FLATBOTTOM WITH 24 HONDA MUD BUDDY MINI TURNING A 12" GDSD PROP/17 FT XPRESS CENTER CONSOLE WITH 90 MARINER
| Thu Apr 11, 2013 6:04 pm |
tailfisher17t
 Re: GDSD Gear Ratio
Interesting prop. I see that it is cut for either a 7/8 or Hex!
| Fri Apr 12, 2013 7:32 am |
Gigafowl
 Re: GDSD Gear Ratio
| Wed Apr 17, 2013 6:56 pm |
tailfisher17t
 Re: GDSD Gear Ratio
I want an 1860 or a 2060 so if you see any for sale let me know. Otherwise I am going to wait till Duckmedic gets hard up and wants to trade or sale me his 1660 until I find a bigger one!!
| Tue Apr 23, 2013 9:23 am |
