| Shaft housing http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=31721 |
| Author: | brock2013 [ Mon Aug 20, 2012 10:43 pm ] |
| Post subject: | Shaft housing |
Where do you get shaft housings? Or do you make them yourselfs? How do you make the housing so the bearings fit? |
| Author: | Sgt Griz [ Tue Aug 21, 2012 1:13 am ] |
| Post subject: | Re: Shaft housing |
Made it 1 1/4 DOM tube three brass bushings 1 in OD 3/4 in ID may have to sand down the out side a little so the fit but not to much drill and tap your tube in the center and 2.5 in from the ends two holes per bushing I taped mine in 1/4 28 place your brass with a wood dowell seals came from carquest again 1 in OD 3/4 in ID your set screws for your bushings should be about 45 degrees apart drill and tap two extra holes for your grease nipples drill and t tap all holes before placing brass |
| Author: | brock2013 [ Wed Aug 22, 2012 9:01 pm ] |
Do you have any pictures of it? |
