fishingandwishing
Joined: Sun Aug 19, 2012 10:00 am Posts: 113 Location: Carencro louisiana
 skeg adjustment motor pulling
my gator tail is finally finished but i find it pulls. do they all pull or is it just mine. also is there anything i can do to fix it or just deal with it. thanks
_________________ 35 efi gtr on a 17 x 54 extreme
| Sun Sep 02, 2012 7:44 am |
Team Camo
 Re: skeg adjustment motor pulling
Bend the torque tab
| Sun Sep 02, 2012 8:12 am |
brianb
Joined: Mon Nov 29, 2010 6:02 pm Posts: 534 Location: louisiana
X2 on bending the torque tab, also make sure u have normal load centered in the boat , having too much weight on one side or the other makes it pull
I used a large cresent wrench and went to the lake and kept bending it till you get all the torque out, mine is at about a 45 degree angle so don't be scared to bend it
_________________ gtr35 gt 1854 / w gatorglide 12 ft 11hp longtail 14 ft 10 hp longtail Merc 225hp TR20
| Sun Sep 02, 2012 8:52 am |
fishingandwishing
thanks i didnt really want to bend it any more than it came but if yours is at about a 45 i will feel safe bending mine a little further
| Sun Sep 02, 2012 8:20 pm |
Gros'bec
Joined: Sat Jul 23, 2011 11:36 am Posts: 235 Location: Louisiana
I bent my Mudbuddy a total of 1 inch further than it came from the factory. It doesn't pull either way now. Just bend a little at a time a try it out before making further adjustments. 3/4" was almost perfect, so I went 1/4" more that did it. I used a pipe wrench and cheater pipe and bent at the factory bend crease, not at the tip.
_________________ 18x44 Gator Trax, Stage 2 Mudbuddy
| Sun Sep 02, 2012 9:22 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Do you have a GT boat and motor or did you just buy the motor and stick it on the boat, if so then make sure motor is correctly centered on transom. first look other than that try what the guys above me said
| Sun Sep 02, 2012 9:48 pm |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
Move your ass 6 inches one way or the other and see what happens before you go bending that tab.
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
| Mon Sep 03, 2012 12:26 am |
fishingandwishing
i do have a gtr on a gator tail boat. i have tried balancing the boat it not that. i will try to bend the tab a little further to see if that helps.
| Mon Sep 03, 2012 10:09 am |
fishingandwishing
i finaly took the boat to a boat launch and bent the tab a little more than it already was. and i bent the piece below it a little. i can now drive my boat effortlessly. thanks for the help
| Tue Sep 18, 2012 8:08 am |
Gros'bec
My boat was perfect after bending skeg 1 inch with no tiller torque at all. Just moved trolling motor battery (74lbs)to rear center to make room for ice chest under the deck and it ain't perfect any more. Just has a little tiller torque now. Plus I lost a tad bit of speed (1 mph)and need to run 100 rpms higher. These boats are finicky.
| Thu Sep 20, 2012 3:10 pm |
Gigafowl
| Thu Sep 20, 2012 3:35 pm |
fishingandwishing
from what i have been told you can move it an inch at a time to find the sweet spot but mine was already bolted center so i just bent the skeg a bit to fix. my motor doesnt pull at all anymore
| Thu Sep 20, 2012 4:47 pm |
