It is currently Mon May 12, 2025 3:37 pm
[ 6 posts ] |
sas8819
Joined: Sat Oct 15, 2011 8:05 pm Posts: 131 Location: West St. Paul, MN
 36 PD trim question.
Was out running the new boat yesterday and got into some nasty mud. I had to trim the motor up and down a lot to get out and at one point the trim stopped working. I'm thinking it might have just got hot and needed to cool down because after about 30 seconds it started working again. My problem is now if your trimming the motor up and stop i have to trim it down first for a little and then i can trim it all the way up. It doesn't matter where you stop at it dose it at any position. Plus when you trimming it up it doesn't seem like there is any power behind it. Any ideas on what could be the issue?
_________________ 1854 Uncle J pushed by a gen 3 PD
Sun Sep 09, 2012 8:58 am |
swampbilly
Joined: Fri Oct 07, 2011 6:08 pm Posts: 1054 Location: Dam-b, Texas
 Re: 36 PD trim question.
Could be a bad switch or air in the hydrolic line. My fpr acted the same and ended up bein the switch.
_________________ pd36 fpr 1754 cc rig
Sun Sep 09, 2012 3:43 pm |
Hog Hunter
Joined: Fri Jun 01, 2012 7:26 pm Posts: 20 Location: Pearl River La.
Check the connections on the switch. Mine was doing the same and it was a loose connection.
Sun Sep 09, 2012 4:34 pm |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
My trim started acting up yesterday. When I try to trim up, it doesn't always respond. It's not slow or anything, it either works or it doesn't. I'm thinking the switch is bad because all my connections are tight.
_________________ 35 GTR - 1754 Extreme
Sun Sep 09, 2012 7:32 pm |
naj
Joined: Fri Jan 22, 2010 8:40 pm Posts: 1620 Location: Larose, Louisiana
Its the switch in both cases. Do yourself a favor and order 2 of them. One for spare.
_________________ 18' X 48" Center Console Sportsman Fab with a Yamaha F70LA 18' X 48" Center Console Sportsman Fab Dragging a 36hp ProDrive 15' X 42" Sea Arch with a 27hp ProDrive
Sun Sep 09, 2012 8:54 pm |
Hog Hunter
Try moving the wires on the switch the next time it happens while pressing the trim switch. I found that the crimp was on the insulation instead of the bare wire causing no voltage and weak voltage.I replaced the push on connector and coated all the connections with dielectric grease. I do carry a spare switch just in case crap happens.
Mon Sep 10, 2012 8:03 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 145 guests |
