It is currently Mon May 12, 2025 3:16 pm
Reply to topic  [ 4 posts ]
 Thrust Loads
Post Thrust Loads
Can this type of bearing handle thrust loads?
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Tue Sep 11, 2012 12:59 pm
Post Re: Thrust Loads
A vigina holds the best thrust load!
just saying.
Tue Sep 11, 2012 1:00 pm
They will hold up to the thrust loads your outdrive is seeing. I have always used single row ball bearings in my builds with no issues. Just make sure it has an appropriate rpm rating for what it will see in your application.
Mag10
Tue Sep 11, 2012 3:56 pm
Lookin to change the bearing system in your home build? What was wrong with the tapered bearings you had before? Just curious cause I'm using the same taper bearings in my build.
14' aluminum can powered by a 16hp GDLT
Wed Sep 12, 2012 6:23 pm
Users browsing this forum: No registered users and 128 guests
