It is currently Mon May 12, 2025 5:57 pm
[ 8 posts ] |
Quack Attacker89
Joined: Fri Feb 04, 2011 3:25 pm Posts: 92 Location: Alvin, TX
 shaft keyway
Ok so I got nearly everything machined for my home build. Only thing left is cutting the keyway where the sprockets attach. I was just wondering what size keyway I need in it. The sprocket is from McMastercarr.com. It has a 3/4" bore but just says standard ANSI keyway.
_________________ 14' aluminum can powered by a 16hp GDLT
Wed Sep 12, 2012 6:29 pm |
50fps
 Re: shaft keyway
Maybe measure the depth of the keyway on the sprocket.
Thu Sep 13, 2012 7:34 am |
Mag10
Joined: Wed Jan 14, 2009 12:31 pm Posts: 342 Location: Faribault, Mn
 Re: shaft keyway
With a .750" bore, it will typically be a .1875" key. I would just buy the sprocket bushing and measure it to be sure.
Thu Sep 13, 2012 11:43 am |
Quack Attacker89
 Re: shaft keyway
I already oredered the sprocket I'm just waiting for it to come in the mail. I'm just trying to get the machining done so when it gets to the house I will have everything I need to start assembling. I guess I'll have to wait till it gets here to mill the keyway.
Thu Sep 13, 2012 10:25 pm |
Rendon_6
Joined: Sat Jun 04, 2011 12:45 pm Posts: 81 Location: Hooper, Utah
 Re: shaft keyway
Should say where ya ordered it from
Wed Sep 19, 2012 6:29 pm |
Quack Attacker89
 Re: shaft keyway
Wed Sep 19, 2012 6:51 pm |
CootSlayerRMFT
Joined: Thu Feb 02, 2012 12:53 am Posts: 7565 Location: Prairieville, LA
 Re: shaft keyway
I hear ya on those brown truck blues. I get them everytime I order anything. I'm sure they have a customer service or tech support line that you could call in the mean time to satisfy your itch...
Wed Sep 19, 2012 6:58 pm |
Gameover
Joined: Tue Jan 03, 2012 9:06 am Posts: 3673 Location: Prarieville,LA
 Re: shaft keyway
For 3/4" shaft a standard ANSI key will be a 3/16x3/16 or 1/4 by 1/4. If 3/16" your keyway cut in shaft needs to be width min .187" max .188" depth min .107" max .113
if 1/4" key width min .249" max .250" depth min .142" max .148
_________________ 1754 GTR Xtreme CC w/ Purple Kool-aid Additives
Thu Sep 20, 2012 5:59 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 103 guests |
