It is currently Mon Jun 30, 2025 9:52 pm
[ 5 posts ] |
HR2labs
 surface drive build
Ok I have built 2 long tails no problems on the 2nd one first one a bit of a learning curve , That being said i going to build a surface drive from what i have read the down tube ( belt housing) needs to be 3 to 4 inches above the bottom of the boat correct and the actuall "shaft tube" needs to be 2 inches above that ,does this sound right also the boat it is going on has a 15 inch transom , this is a winter project Thanks for your help Mario
Thu Nov 22, 2012 6:29 pm |
mud slinger 69
Joined: Sun Aug 28, 2011 4:27 pm Posts: 1194 Location: Utah
 Re: surface drive build
Sounds about right.Good luck
_________________ We ant just mormons and polyganists we got rednecks too
Fri Nov 23, 2012 7:37 am |
HR2labs
Thanks Mario
Fri Nov 23, 2012 5:20 pm |
blmaloney
Yes. The housing needs to be about 2 inches above the bottom of the boat. As far as the exit for the shaft tube that will depend on the size of pully you use. One of the other issues you will have if you have not addressed it yet is shaft bearings and seasl.
Wed Dec 19, 2012 2:38 pm |
HR2labs
Thanks I have started having the bearing and shaft housing machined bought bearing and seals hopefully it will be done saturday an d thanks for the heads up on the pulley size
Wed Dec 19, 2012 8:41 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 82 guests |
