It is currently Fri Dec 26, 2025 4:47 am
Reply to topic  [ 6 posts ]
 PD Prop bushing
Post PD Prop bushing
In most cases when the prop is removed the taper bushing will remain in the prop. To remove the bushing use vise grip pliers or channel locks as shown below to compress the bushing and twist slightly....Tried this just not working. Any special way of getting this bushing out or trick. This is my first PD any help would be great.
Tue Feb 12, 2013 1:51 pm
Post Re: PD Prop bushing
new prop? you should use a new bushing
I gave up mud motors
Tue Feb 12, 2013 1:52 pm
Old prop took it off to grease everything.
Tue Feb 12, 2013 1:56 pm
Get a bigger pair of pliers, if there is enough bushing sticking out of the prop, you can squeeze it and get it out, if not drill a hole in the bushing directly across from the groove that is already in it the lentgh of the bushing (basically drilling another grove on the other side) it will come out easy then.
Tue Feb 12, 2013 2:04 pm
Thanks
Tue Feb 12, 2013 2:09 pm
Mon Feb 18, 2013 11:21 pm
