| Loose skeg PD 32 http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=37870 |
| Author: | zibilich [ Wed Feb 20, 2013 4:28 pm ] |
| Post subject: | Loose skeg PD 32 |
The skeg on my 05 prodrive 32 is pretty loose. Rattles its ass off while running. Anyone know how these things mount? Replacement? |
| Author: | Will [ Wed Feb 20, 2013 4:31 pm ] |
| Post subject: | Re: Loose skeg PD 32 |
I wish that was the only problem i had, I'm fucking stuck, 300 yards from anything to hook the winch to... |
| Author: | deltaduckmaster [ Wed Feb 20, 2013 4:32 pm ] |
| Author: | txmudcutter [ Wed Feb 20, 2013 4:34 pm ] |
| Author: | zibilich [ Wed Feb 20, 2013 4:34 pm ] |
Lol just bought the boat 2 weeks ago and noticed it last time out. Its still connected but it moves the motor side to side its so loose. |
| Author: | Will [ Wed Feb 20, 2013 4:36 pm ] |
It snuck up on me...in the truck, put it in drive, get out and all fours turn...i might be here for a minute... |
| Author: | bmartina [ Wed Feb 20, 2013 4:36 pm ] |
| Author: | deltaduckmaster [ Wed Feb 20, 2013 4:37 pm ] |
That's what pd guys are always screaming so it fit |
| Author: | duckduckboom [ Wed Feb 20, 2013 4:39 pm ] |
You see these those Allen bolts on your skeg. Tighten those |
| Author: | Will [ Wed Feb 20, 2013 4:39 pm ] |
| Author: | Kmoppert [ Wed Feb 20, 2013 4:41 pm ] |
| Author: | zibilich [ Thu Feb 21, 2013 9:21 am ] |
| Author: | OwenDickeson [ Thu Feb 21, 2013 9:22 am ] |
take pictures of yours and post them. |
| Author: | zibilich [ Thu Feb 21, 2013 9:33 am ] |
| Author: | bayouboy [ Thu Feb 21, 2013 9:46 am ] |
Your skeg is worn from the vibration. The old style L/Us (like yours) uses the method of pulling each side the slot to hold/clamp the skeg in place it will only pull so far, the newer style uses the bolts nut. If you skeg is still in decent shape on the bottom . I would remove it and insert some calking or silicone in the slot reinstall the skeg and bolts ( but don't tighten it yet) wipe off the excess, let it cure then tighten it back down. If you have the spare change I'd go with a new one. Let me look my boy, I may have one laying around. |
| Author: | zibilich [ Thu Feb 21, 2013 10:05 am ] |
| Author: | bayouboy [ Thu Feb 21, 2013 10:31 am ] |
I found two. |
| Author: | zibilich [ Thu Feb 21, 2013 7:42 pm ] |
| Author: | bayouboy [ Thu Feb 21, 2013 8:53 pm ] |
| Author: | zibilich [ Sun Feb 24, 2013 9:51 am ] |
| Author: | JLACOUR [ Sun Feb 24, 2013 10:00 am ] |
My skeg has about a 2 inch hairline crack by the prop. I'm going to weld it and see how long that last. If not, I will be on the hunt for a new or used one. |
| Author: | flatboat [ Sun Feb 24, 2013 1:05 pm ] |
Just let bayouboy build you a new one. U won't regret it |
| Author: | JLACOUR [ Sun Feb 24, 2013 2:48 pm ] |
Bayou-- send me some pics and a price. |
| Author: | tchauvin [ Sun Feb 24, 2013 3:22 pm ] |
Mines and one other was cracked to! They all crack in same place cause of the hole drilled! x100 on the skeg from bayou boy! U won't regret it! |
| Author: | CCC [ Sun Feb 24, 2013 3:29 pm ] |
How much does bayou boy charge? |
| Author: | tchauvin [ Sun Feb 24, 2013 3:44 pm ] |
| Author: | flatboat [ Sun Feb 24, 2013 5:19 pm ] |
| Author: | CCC [ Sun Feb 24, 2013 7:25 pm ] |
I sent a pm thanks |
