36PD foot problem
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=38125
Author:  Machinist5381 [ Tue Feb 26, 2013 9:21 pm ]
Post subject:  36PD foot problem
I am having a problem with my foot swinging all the way back in forward. It looks like it would be a tooth off. I just bought the boat about a month ago and it has 250+ hours on it... It is starting to have a problem swinging into reverse. It sounds and looks like it is struggling to turn and then to finish turning to full reverse. Thanks for any help on this!!!
Author:  med [ Tue Feb 26, 2013 10:01 pm ]
Post subject:  Re: 36PD foot problem
What yr is it? Thete was a guy that had a similiar problem a while back and pd fixed it. Some sort of recall on a part. Might check that pin and make sure its operating properly.
Sent from my DROIDX using Tapatalk 2
Author:  naj [ Tue Feb 26, 2013 10:06 pm ]
I think he is talking about Hydro Reverse.
There was a problem with the cylinder sealleaking fuid by. Mine used to do that. Got a free seal kit and rebuilt it myself.
Never had problem again.
Author:  bayouboy [ Tue Feb 26, 2013 10:25 pm ]
A quick way to trouble shoot it is to disconnect the cylinder from the outer gear arm and move the lower unit around manually to see if it binding. If it is binding grease it at all 5 points and at quarter turns . If the lower unit does move free then actuate the cylinder back in and out, if the cylinder fails to fully stroke then you either have bad seals or pump issues or low fluid. If everything checks out then look at the gear under the clutch and make sure the teeth are clean and clear of debris. The smallest rock, shell or what ever in the lash will cause it to bind.
Author:  CJB [ Tue Feb 26, 2013 10:27 pm ]
And if all of the above doesn't help, go see Mike at H&H. He'll fix you up
Author:  Machinist5381 [ Wed Feb 27, 2013 5:15 am ]
Thanks everyone.... It is a 08 and I will try all of that this weekend. I am trying not to bring it to H&H...$85per hour!!!
Author:  Buzz Killington [ Wed Feb 27, 2013 7:59 am ]
Haven't you heard? Mudmotors are EXPENSIVE! !!
hope you get it fixed. No fun when the toys are broken
