It is currently Wed Mar 18, 2026 2:38 pm
Reply to topic  [ 2 posts ]
 need info on greasing the mid section on a pro drive
Post need info on greasing the mid section on a pro drive
ok well I greased the lower unit an a few other grease inserts an after a few pumps grease starts coming out some wheres..........but they have a grease inserts on the left top side of the midsection if ur looking at the muffler well I put probly 25 to 30 pumps of grease in it an grease dose not come out no wheres but it sounds like grease is coming out some times..............im wondering if i might have busted a seal
Sun Jun 23, 2013 7:18 pm
Post Re: need info on greasing the mid section on a pro drive
The two zerks in the tower are just greasing the tower bushings. There is a lot of dead space in there so if there wasn't much grease in there, it will take quite a bit. It will come out in between the LU and the tower and up around the reverse plate when it's full. Put it in reverse, back to forward, and work the LU quite a bit when filling it up to make sure you get it worked in there good. No seals in there to worry about.
Sun Jun 23, 2013 8:13 pm
