Copperhead 18 belt issues http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=47417 |
Author: | shotgunwilly1117 [ Fri Nov 15, 2013 9:49 am ] |
Post subject: | Copperhead 18 belt issues |
Last night my belt kept slipping off so I barely made it off the lake. I already has an extra belt just in case so I swapped em out this morning. Comparing the new and old belts it's safe to say it was time. After i got the new belt on I noticed it slips back way off of the gear when running. Is this normal or is something wrong? |
Author: | bengtr35 [ Fri Nov 15, 2013 10:41 am ] |
Post subject: | Re: Copperhead 18 belt issues |
You need to tighten your belt by shimming your engine up. By the amount of rubber on the back of the engine it has been slipping for a long time. |
Author: | shotgunwilly1117 [ Fri Nov 15, 2013 11:01 am ] |
What do I shim it with? |
Author: | bengtr35 [ Fri Nov 15, 2013 12:22 pm ] |
Most auto part stores sell shims. If not you can put a washer. |
Author: | shotgunwilly1117 [ Fri Nov 15, 2013 12:40 pm ] |
Alright thank ya |
Author: | Jbh0724 [ Sat Nov 10, 2018 10:09 am ] |
Where would you put the shims to correct this issue? |
Author: | Jbh0724 [ Sat Nov 10, 2018 10:19 am ] |
Author: | tryan [ Mon May 27, 2019 11:12 am ] |
Underneath the motor where it mounts to the frame. Also the teeth on the belt should be facing inwards to sit inside the teeth on the sprockets. |
Author: | Will C [ Thu May 30, 2019 12:11 am ] |
The upper pulley should have a guide ring like on the front of sprocket. |
