Big Blade or ???
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=50011
Author:  dillakilla12 [ Tue Feb 04, 2014 5:46 pm ]
Post subject:  Big Blade or ???
Motor/prop has right at 50 hours. 23 mini lite. Its supposed to have a big blade on it but its not measuring up. Is it possible that they put the 11x10 on there or could it have worn down this much???? Haven't really been in any sand. The big blade is like 12.25x10. I feel like my motor has more to offer and the prop is where I'm looking for the added performance. I've never played with props on these motors before so just looking for some guidance.
Sent from my DROID RAZR using Tapatalk 4 Beta
Author:  dillakilla12 [ Tue Feb 04, 2014 5:55 pm ]
Post subject:  Re: Big Blade or ???
Or am I measuring wrong?
Author:  msm8281 [ Tue Feb 04, 2014 5:58 pm ]
How many hours u have on it and are your rpms higher now then it was new?
BTW even though u think its just mud there is still fine sand mixed in there that will gradually eat up a prop. It doesn't have to be hard packed sand.
Author:  dillakilla12 [ Tue Feb 04, 2014 6:04 pm ]
50 hours, and I haven't noticed to much change in RPMs. Most of the hours were on my Triton. I probably only have about 15 hours on the motor on my new hull. I want to say I was running between 4500 to 4750 when it was on my Triton but here lately I'm noticing around 4300 to maybe 4400
Author:  msm8281 [ Tue Feb 04, 2014 6:11 pm ]
Sound like a lot if rpms for a 23. Any work done to the motor.
Author:  dillakilla12 [ Tue Feb 04, 2014 6:13 pm ]
Heads, cam, rockers and rods, mikuni, crossover exhaust
Author:  LA Prop [ Tue Feb 04, 2014 6:56 pm ]
i cant see that little motor turning a 12.25 prop jmo
u may have worn just the cup off and having to trim down to make it grab i cant see u loosing an inch of prop in 50 hours on a mb prop
Author:  dillakilla12 [ Tue Feb 04, 2014 7:49 pm ]
It says on the web that they come with the big blade. I dunno. Seems like I have a lot of ware or they put the wrong prop on it.
Author:  LA Prop [ Tue Feb 04, 2014 8:18 pm ]
yea seems like alot
Author:  Woodiebuster [ Tue Feb 04, 2014 8:43 pm ]
What year is it?
I always thought that the minis came with a 11" and the 23 Sports had a big blade.
Seems like I remember someone saying a Big blade wont clear the mini's cavitation plate.
Author:  AirFido [ Tue Feb 04, 2014 8:54 pm ]
Look close at the hub. Mine is stamped with size
Author:  dillakilla12 [ Tue Feb 04, 2014 8:59 pm ]
Well AirFido you are correct. At a closer glance it is stamped 11x10. But MB advertises the big blade on the web and its showing it with the cav plate.
Author:  dillakilla12 [ Tue Feb 04, 2014 9:01 pm ]
Author:  270Handiman [ Tue Feb 04, 2014 9:06 pm ]
I can't see a stock 23 coming with a big blade. A stock 35 will only spin it to around 4300. You call MB to ask about this yet?
After mods, you should be able to spin it. Order one and give it a shot.
Author:  AirFido [ Tue Feb 04, 2014 9:49 pm ]
I am a MB owner, but their site and it's content is a hot mess.
Author:  dillakilla12 [ Tue Feb 04, 2014 9:57 pm ]
Haven't called them yet. I'm just toying with the idea of a custom prop or trying something different
Author:  bmartina [ Tue Feb 04, 2014 11:24 pm ]
I had an un modded 27 Kohler mini light , got tired of the little prop so I ordered the bigger one was slower at first but with a little wear worked great ... My buddy is using my worn big Gtr prop for his little 25 and got his best speeds out of the bigger worn prop
Author:  Wildberry [ Wed Feb 05, 2014 5:09 am ]
Author:  dillakilla12 [ Wed Feb 05, 2014 5:49 am ]
I'm gonna take another measurement to see if I can clear the big blade. I'm thinking with my mods I might can turn it.
Author:  Woodiebuster [ Wed Feb 05, 2014 1:59 pm ]
They gear the 23's down pretty good to sling a big blade, I don't know how stout your motor is but I'm willing to bet the stock setup gear for a 11x10 won't sling it
Author:  North LA Hunter [ Wed Feb 05, 2014 3:32 pm ]
My 23 la special came with a bb on it. I wore it out and put a 12x12 Hopkins on it and ran good. Don't know if there's any difference in the mini lite and la special gear ratio though.
Sent from my beeper
Author:  dillakilla12 [ Wed Feb 05, 2014 5:36 pm ]
Hell I don't know what the difference would be!
Author:  North LA Hunter [ Wed Feb 05, 2014 5:37 pm ]
Author:  North LA Hunter [ Wed Feb 05, 2014 5:41 pm ]
Mine had exhaust and I could turn the big blade good.
Sent from my beeper
Author:  dillakilla12 [ Wed Feb 05, 2014 7:49 pm ]
Thanks for the advice fellas
Author:  HUNT4DEER [ Sat Feb 15, 2014 6:44 pm ]
not sure a bb will clear the cavatation plate on a mini?
