It is currently Thu Dec 25, 2025 9:18 am
Reply to topic  [ 2 posts ]
 Pulley vs sprocket lower unit?
Post Pulley vs sprocket lower unit?
Which one for the lower unit drive shaft? Would it matter? Seems like the pulley would be best?
16' skiff 23 GDLT
Sat Feb 08, 2014 10:57 am
Post Re: Pulley vs sprocket lower unit?
Well sprocket your talkin chain which wouldn't give much if your hitting hard objects... pulley will have some forgiveness when you do strike something hard... We've used the gt2 (I think) by gates and it has worked flawlessly, but I have heard of others on here particularly Mark C. who uses a different setup that should work and is less expensive? I'm sure he'll chime in! good luck!
1436 Lowe
Sat Feb 08, 2014 9:36 pm
