It is currently Tue May 13, 2025 12:22 am
Reply to topic  [ 15 posts ]
 Anyone ever chased threads on a 3/4" SS shaft with a die?
Post Anyone ever chased threads on a 3/4" SS shaft with a die?
Good grief. What a nightmare.
I'm trying to figure out what was worse--the ineffectualness of trying to do it with a big wrench (the shaft spins with any substantial pressure), or the host of other yet equally insidious problems caused by trying to accomplish the job using an air impact wrench.
No amount or type of oil seemed to eliminate the tendency to gall.
NO WONDER the hex shaft succeeded the threaded shaft.
Tue Feb 25, 2014 11:31 pm
Post Re: Anyone ever chased threads on a 3/4" SS shaft with a die
You tried a Ridgid power pony or power machine???
Wed Feb 26, 2014 5:12 am
Call some machine shops. Should only be 20 bucks or so. Of course you have to take the dam thing apart.
Wed Feb 26, 2014 5:30 am
B. MacDonald
Wed Feb 26, 2014 6:00 am
1754 XSeries Kawi Powered PRODRIVE ...
Wed Feb 26, 2014 6:04 am
Use mustard instead of oil and go slow.
18x54 WC custom
36PD EFI
Wed Feb 26, 2014 6:31 am
Wed Feb 26, 2014 6:43 am
Wed Feb 26, 2014 7:14 am
Get a good die adjustable one open it up do a few diffrent cuts.
Wed Feb 26, 2014 7:34 am
Wed Feb 26, 2014 8:15 am
Look into a local machine shop making you a whole new shaft.
A 30" round stock with a 10tpi thread on one end and a keyway on the other cant cost that much.
I've chased the threads on my 3/4" longtail shaft. You just need to engage the clutch and get some way to keep the motor from spinning over while you turn your wrench.
Wed Feb 26, 2014 9:38 am
u can use a regular 3/4-10 die to chase it u may need to pull the shaft though
Wed Feb 26, 2014 9:46 am
Wed Feb 26, 2014 10:20 am
That's what I do on mine, His SD don't have no u-joint though!
Wed Feb 26, 2014 5:19 pm
You can do it by hand with a fixed die and never seize. Take it a little at a time. Just have to find a way to lock down your shaft.
Wed Feb 26, 2014 5:37 pm
Users browsing this forum: No registered users and 94 guests
