| GTR lower unit grease not coming out http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=52298 |
Page 1 of 2 |
| Author: | cut'em94 [ Sat Apr 12, 2014 6:25 pm ] |
| Post subject: | GTR lower unit grease not coming out |
I searched and couldn't find anything, so I figured I'd ask. I took out the screw and pumped a couple pumps and the old grease starting coming out. After a couple more pumps, no grease came out. Gave it another 10 or so pumps and still nothing. I waited a couple minutes and pumped another 5 or so and nothing came out. Its not coming out any of the seals, which is a good thing, but I don't understand how it could get clogged. And yes I made sure the grease gun still had grease in it. Any thoughts? |
| Author: | msm8281 [ Sat Apr 12, 2014 6:28 pm ] |
| Post subject: | Re: GTR lower unit grease not coming out |
Keep pumping till your arm hurts. It'll come out eventually:lol: |
| Author: | Mudmotor Slayer [ Sat Apr 12, 2014 6:30 pm ] |
When I put grease in my Lu I remove screw and then start motor put in gear and pump grease till it comes out just remember the prop is unforgeven |
| Author: | cut'em94 [ Sat Apr 12, 2014 6:33 pm ] |
I just don't get why it was coming out and then it stopped. I dont want to mess up anything else. |
| Author: | jldsc [ Sat Apr 12, 2014 6:39 pm ] |
Mine does the same thing sometimes...just a pocket of air...as long as the screw is out it shouldnt blow a seal. Keep pumping Sent from an Apple Tree.. |
| Author: | jc [ Sat Apr 12, 2014 6:42 pm ] |
^^^^^ This ^^^^ Keep pumping, just an air pocket. |
| Author: | MarshJB [ Sat Apr 12, 2014 7:14 pm ] |
I've pumped about ten times with nothing coming out. Sent from my XT1080 using Tapatalk |
| Author: | baron von [ Sat Apr 12, 2014 7:31 pm ] |
are you using a cheap grease gun? I went thru about 5 of those things till I switched to air one |
| Author: | eljefe [ Sat Apr 12, 2014 7:53 pm ] |
Turn your prop 4 or 5 revolutions... it will free it up and start coming out. you drink the kool aid, id rather drink the whiskey and raise hell!!!! |
| Author: | TPerkins [ Sat Apr 12, 2014 8:29 pm ] |
I keep hearing about seals, is it possible with a GT to blow the seals? I've topped mine off many times without removing the screw. My grease has never been off color. |
| Author: | cut'em94 [ Sat Apr 12, 2014 8:39 pm ] |
I've put about 2 whole cans of grease in there. The old grease is coming out, just very slowly. Turning the prop helped, but it is still very slow. Guess ill get a third can... |
| Author: | msm8281 [ Sat Apr 12, 2014 8:41 pm ] |
Quit playing with that baby gun and get a fullsize one. Them lil minis hardly have any grease in those tubes. |
| Author: | baron von [ Sat Apr 12, 2014 9:28 pm ] |
you will like this - it kicks @ss http://www.amazon.com/Lincoln-1162-Air- ... B0019COQ6C |
| Author: | cut'em94 [ Sat Apr 12, 2014 9:30 pm ] |
Yea I might have to invest in one of those. |
| Author: | baron von [ Sat Apr 12, 2014 9:35 pm ] |
I bought one 3 years ago - cannot live with out it now. |
| Author: | forever draggin [ Sat Apr 12, 2014 9:57 pm ] |
I been contemplating getting one for a few years.. |
| Author: | Bigrich [ Sat Apr 12, 2014 10:35 pm ] |
| Author: | AKA Freshwaterkilla [ Sat Apr 12, 2014 10:47 pm ] |
I have a cordless one its pretty bad ass Sent from my iPhone using |
| Author: | Team Schmo [ Sun Apr 13, 2014 8:51 am ] |
I use a Lincoln as well, but I have battery powered instead of air. Works great IMO.. |
| Author: | cupped up [ Sun Apr 13, 2014 8:52 am ] |
This thread made me laugh. |
| Author: | baron von [ Sun Apr 13, 2014 8:58 am ] |
^^ cheap entertainment is hard to find |
| Author: | baron von [ Sun Apr 13, 2014 9:20 am ] |
| Author: | cut'em94 [ Sun Apr 13, 2014 2:20 pm ] |
I'm down to my last tube of grease. I have put 5 in there. It's still barely coming out and its a dark greyish in color so I know they still have old grease in there. I never had this problem with my other motor. |
| Author: | MarshJB [ Sun Apr 13, 2014 2:30 pm ] |
I'm afraid to say that i think there is a possibility you filled up the belt housing. Sent from my XT1080 using Tapatalk |
| Author: | Gameover [ Sun Apr 13, 2014 2:32 pm ] |
You are def putting it in belt housing, that will be fun to clean. |
| Author: | cut'em94 [ Sun Apr 13, 2014 2:36 pm ] |
Fuck. Is there any easy way to clean it out? And I'm going to guess no... |
| Author: | MarshJB [ Sun Apr 13, 2014 2:36 pm ] |
| Author: | cut'em94 [ Sun Apr 13, 2014 2:44 pm ] |
Guess ill be heading to gatortail tomorrow. Is this a common thing? |
| Author: | MarshJB [ Sun Apr 13, 2014 2:58 pm ] |
And this is why i purge my LU every time i use it. I honestly don't know. I'll never have this issue because I'm a maintenance freak. Sent from my XT1080 using Tapatalk |
| Author: | msm8281 [ Sun Apr 13, 2014 2:59 pm ] |
No its not common. How many hours you have on that thing? How often do you grease it? |
| Author: | Nate [ Sun Apr 13, 2014 3:16 pm ] |
The seals fail, some sooner than others. If you shine a flashlight down your belthousing u will see the pile of grease at the bottom i am guessing. Pull the lower unit and replace seal at a minimum, if i recall its like 15 bucks. Be sure to inspect bearing, race etc while u got it apart. Alot will say replace everything while u got the bitch apart, up to u. Belt housing not hard to clean out just messy. |
| Author: | cut'em94 [ Sun Apr 13, 2014 3:27 pm ] |
I just bought it 2 fridays ago from someone. The motor has 12 hours on it. |
| Author: | eljefe [ Sun Apr 13, 2014 3:43 pm ] |
I bet it's never been maintenanced. ... prolly original oil....what year is it? you drink the kool aid, id rather drink the whiskey and raise hell!!!! |
| Author: | Bigrich [ Sun Apr 13, 2014 3:53 pm ] |
Must been bad seal from get go with if only 12 hrs on it |
| Author: | Team Schmo [ Sun Apr 13, 2014 3:58 pm ] |
| Author: | baron von [ Sun Apr 13, 2014 4:07 pm ] |
| Author: | Team Schmo [ Sun Apr 13, 2014 4:11 pm ] |
For his sake I hope 3 ounce.. |
| Author: | msm8281 [ Sun Apr 13, 2014 4:18 pm ] |
12 hrs....Is that the original tach? |
| Author: | cut'em94 [ Sun Apr 13, 2014 5:11 pm ] |
Everything was a 2012 on the motor, but the motor had some sort of defect and he got a new one which is why it only has 12 hours on it. The frame and the rest stayed the same. But I talked to him and he said he purged the grease every 15 hours. And no, I'm talking about 5 14oz tubes of grease. That's why I was so skeptical to keep pumping after 2. This is the first time I have purged the grease on a 35 hp, I have only done it on my 25hp, so I figured it might take more... Guess I was wrong. Its definitely in the housing because i see it on the belt because I was turning the prop to help the grease come out of the screw hole. So let's just say there isn't much friction on the belt right now. |
| Author: | baron von [ Sun Apr 13, 2014 6:00 pm ] |
that's almost 5 pounds of grease |
| Page 1 of 2 | All times are UTC - 6 hours |
