It is currently Wed Dec 24, 2025 4:30 pm
[ 9 posts ] |
BayouStateHunter
Joined: Sat May 16, 2009 1:04 pm Posts: 2037 Location: On da Northshore -- Louisiana
 GT lower unit rebuild.
Anybody got any pics of the guts before I crack it open? I got the rebuild kit in and will take a stab at it this weekend. There are a shitload of o rings.... Thread research didn't prove extremely fruitful.
_________________ 1860 GTB/35GTR CC w/ Hoyt Stage 1 - bowfishin'/rodnreel/duckhunting
| Thu May 01, 2014 7:45 pm |
BayouStateHunter
Pulley and taper lock are rusted bad. I out the Allen head screw in the extra hole and it won't back the taper off the pulley. I soaked it in WD40 to no avail. I beat the piss out of it with a plastic hammer away from the prop. Does it do any good to beat the pulley towards the prop or should I be hitting the taper lock only?
Also do you leave the Allen screw in while you attempt to get the pulley off?
| Fri May 02, 2014 6:06 pm |
BayouStateHunter
 Re: GT lower unit rebuild.
| Fri May 02, 2014 6:22 pm |
AKA Freshwaterkilla
No u only hit the pulley toward the lower unit mounting flange and keep tightening the Allen in taper lock
Sent from my iPhone using
| Fri May 02, 2014 6:34 pm |
BayouStateHunter
The bitch is stuck and rusted bad. She's not cooperating.
| Fri May 02, 2014 8:20 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
Heat it up
| Fri May 02, 2014 8:26 pm |
BoatDR
| Fri May 02, 2014 8:41 pm |
AKA Freshwaterkilla
| Fri May 02, 2014 10:33 pm |
BayouStateHunter
After a lengthy soaking in penetrating oil and a beat down by a new $6.00 rubber mallet. Thanks for the help guys.
| Sat May 03, 2014 6:31 pm |
[ 9 posts ] |
