hammer prop wear
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=55079
Author:  LA Prop [ Thu Jul 24, 2014 9:52 am ]
Post subject:  hammer prop wear
Just wonder how fast they wearing on others..
I put one in march and have 100hours on it now and looks like I've got about 1/4" of wear haven't lost anything from it yet..
Author:  msm8281 [ Thu Jul 24, 2014 9:54 am ]
Post subject:  Re: hammer prop wear
How many rpms you turning with it.
Author:  LA Prop [ Thu Jul 24, 2014 9:59 am ]
New I could bury it and turn 3980
I run my motor at 4050 or less I try not to run higher than that
Author:  DmaxHunter [ Thu Jul 24, 2014 11:16 am ]
Mine has about thirty his on it wear is low. However I used to run 4450 now I'm at 4500 to 4540. It's picking up speed, I've noticed it takes allot to wear it down
Author:  3rd Coast Killer [ Fri Jul 25, 2014 9:01 am ]
I have a 1-1/2 duck season on mine, and i guess 100 hours or so.
I have lost about 1/4" to 1/2" and it still runs good.
Brand new my motor would only turn it about 4200, now i can turn it up to 4500 in deep water.
I did go back to a stock prop recently for about 10 minutes, but it was so unbalanced i couldnt stand it.
My next prop will be another Hammer.
Author:  BoatDR [ Fri Jul 25, 2014 9:15 am ]
It really depends on the bottom of where you run. My customers that run in hard packed sand bottom go thru about a prop a year. In area where the mud is bottomless, they get many years of use out of their prop.
I've got about 700 hours on my current hammer and have only lost about 1/4" of it, but if you jumped out of the boat in the mud where I hunt you'd sink to your armpits.
Author:  JD145 [ Fri Jul 25, 2014 9:24 am ]
i havent used my hammer alot. it seemed to me i got more rpms and speed out of the big blade. when i had the hammer on i didnt hit 4500, more like high 4300s. is this others experience mostly?
Author:  3rd Coast Killer [ Fri Jul 25, 2014 9:27 am ]
Author:  JD145 [ Fri Jul 25, 2014 9:30 am ]
when i bought the hammer i really was thinking of the hole shot and load carrying potential for duck season. my motor would run 4700 with the big blade if i was willing to turn her that hard. i try to keep it under 4500 and plan to use the hammer when im hauling 1200 pounds of decoys, shotguns and ass :lol:
Author:  BoatDR [ Fri Jul 25, 2014 9:36 am ]
Author:  lunacris [ Fri Jul 25, 2014 9:42 am ]
I can hit 4650 a wot with mine.
JD did you get the new gearing when you got your hammer?
Author:  LA Prop [ Fri Jul 25, 2014 9:49 am ]
Author:  LA Prop [ Fri Jul 25, 2014 9:51 am ]
Author:  3rd Coast Killer [ Fri Jul 25, 2014 9:55 am ]
Author:  LA Prop [ Fri Jul 25, 2014 12:23 pm ]
Author:  SCmudder7071 [ Fri Jul 25, 2014 12:54 pm ]
I put about 30hrs on a hammer in everything from rocky rivers, sandy lakes, tidal mud, etc and might have lost an 1/8". Guy who bought my rig still has it and last I heard from him, he's got over 100hrs and is down to 12.25 but said that was his fault because he buried it in a real sandy mud a couple of times but that it still pulls really good.
Author:  JD145 [ Fri Jul 25, 2014 8:45 pm ]
Author:  lunacris [ Fri Jul 25, 2014 9:05 pm ]
your getting 4300 with a 55mag at full throttle with a hammer?
Author:  JD145 [ Fri Jul 25, 2014 9:17 pm ]
maybe 4250? in that neighborhood i didnt have the prop on long and it has been a while back
Author:  lunacris [ Fri Jul 25, 2014 9:21 pm ]
different gear should allow you to achieve more rpms. i have a same motor and can't see any other reason why you aren't turning around the same as mine.
boat dr should be able to explain it a hell of a lot better than me
Author:  JD145 [ Fri Jul 25, 2014 9:31 pm ]
i'll have to slap it back on and try this again....maybe my valve lash needs adjusting but i doubt it. i just recently upgraded my motor from 45 mag
Author:  JD145 [ Fri Jul 25, 2014 9:34 pm ]
Author:  lunacris [ Fri Jul 25, 2014 9:36 pm ]
no, so far I've just run a hammer with this motor.
Author:  JD145 [ Fri Jul 25, 2014 9:36 pm ]
and i'm assuming you did the gear upgrade?
Author:  lunacris [ Fri Jul 25, 2014 9:39 pm ]
Author:  DmaxHunter [ Sat Jul 26, 2014 4:32 am ]
Stock gears on my mag, turning hammer at 4450 to 4500 now. Was 4400 brand new
Author:  Puddler45 [ Mon Jul 28, 2014 2:43 pm ]
anyone ever put a hammer prop on a 23. I am about to do a stage 1 upgrade and depending on what rpms im turning I would consider a hammer. I am turning 3800-4000 rpms right now at top speed depending on load and water depth/wave conditions.
Author:  LA Prop [ Mon Jul 28, 2014 2:47 pm ]
Author:  Puddler45 [ Mon Jul 28, 2014 2:59 pm ]
my buddy has one right now I could see about buying his and he could get a new one after this duck season and has a little wear on it. He only has about 10 hrs on it now. I would only consider it if I can hit the 4350 rev limiter after the upgrade otherwise i will stick to the big blade im running now.
Author:  THE TANK [ Mon Jul 28, 2014 3:16 pm ]
I got something better then the hammer prop, LA prop saw big Bertha and her sister! Them blades are fat like a big fat Bertha that's 450 ibs on the huff!
Author:  lunacris [ Mon Jul 28, 2014 3:24 pm ]
Are you selling those for 550 too
Author:  THE TANK [ Mon Jul 28, 2014 3:56 pm ]
Author:  LA Prop [ Mon Jul 28, 2014 5:28 pm ]
