It is currently Thu Dec 18, 2025 1:45 am
Reply to topic  [ 6 posts ]
 PD gear oil?
Post PD gear oil?
i just recenty upgraded to a pro drive and was wondering if you can over fill the gear oil reservoir? i drained it and filled it up until it was over flowing then squirted a little more and capped it really fast. so that none would run out, will it be ok?
WingPhenes™
18x54 ProDrive Powered James Gang Bang
Fri Jul 25, 2014 6:36 pm
Post Re: PD gear oil?
Yea you will be good. When u fill from the back hole and u see it come out the front put ur plugs back in and you will be good to go.
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Fri Jul 25, 2014 7:56 pm
^ Correct, All depends on the year of the L/U. The old style (07-10 oil bath prop shaft) will require a little more oil and if you filled it from the top you may want to recheck it. It takes a while to drain down. New style 11-14 greased shafts and oil bath gears not an issue when filling.
Fri Jul 25, 2014 8:25 pm
Ok this is a 2012. So should I refill it from the bottom or let her roll
WingPhenes™
Fri Jul 25, 2014 9:27 pm
2012 your good to go my boy!!
Wait! I said that a little premature my boy. Did you also grease the shafts?
Fri Jul 25, 2014 9:32 pm
Yes sir, all greased up. Thanks for the help!
WingPhenes™
Sat Jul 26, 2014 10:13 am
