2014 pd manual reverse has a jerk in it http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=55106 |
Author: | Riverrats1 [ Fri Jul 25, 2014 11:37 am ] |
Post subject: | 2014 pd manual reverse has a jerk in it |
Just got a 2014 36 pd short shaft put on my 06 pd boat. The last motor a 06 36 would randomly jerk in your hand and feel like it was missing. I thaught it was worn out. On my brand new 0 hour motor it does the same thing. It feels like you are lightly bumping a stump every 10 to 20 seconds in open water. Also my boat will plane out good, all of a sudden the handle will have a little pull to it and the nose will plow for a couple seconds the plane back out again repeatadly. Please help very frustrated!!!! |
Author: | Quack Stackin [ Fri Jul 25, 2014 11:53 am ] |
Post subject: | Re: 2014 pd manual reverse has a jerk in it |
does it happened when trimmed down well below the surface? the small jerk happens on my mudbuddy and its just the nature of the briggs I believe |
Author: | Riverrats1 [ Fri Jul 25, 2014 12:07 pm ] |
Trimming it in normal running position or below the surface it does it. It may be normall but I know the nose plowing then lifting back up is not normall. I'm going to bend the trim tab up a little bit and see how that does. |
Author: | Riverrats1 [ Fri Jul 25, 2014 3:19 pm ] |
Talked to prodrive and believe we've got it narrowd down to a boat hull issue. Thanks |
Author: | Swamp Wader [ Sun Jul 27, 2014 11:59 am ] |
I was gonna say you may have some bad hooks in your hull. What the bottom look like |
Author: | OwenDickeson [ Sun Jul 27, 2014 1:39 pm ] |
Hooked boat. |
Author: | bayouboy [ Sun Jul 27, 2014 6:11 pm ] |
If its doing the same thing with 2 different motor than that only leave the boat. |
