PD gear oil? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=55117 |
Author: | EastTexasDucks [ Fri Jul 25, 2014 6:36 pm ] |
Post subject: | PD gear oil? |
i just recenty upgraded to a pro drive and was wondering if you can over fill the gear oil reservoir? i drained it and filled it up until it was over flowing then squirted a little more and capped it really fast. so that none would run out, will it be ok? |
Author: | Quackhead62 [ Fri Jul 25, 2014 7:56 pm ] |
Post subject: | Re: PD gear oil? |
Yea you will be good. When u fill from the back hole and u see it come out the front put ur plugs back in and you will be good to go. |
Author: | bayouboy [ Fri Jul 25, 2014 8:25 pm ] |
^ Correct, All depends on the year of the L/U. The old style (07-10 oil bath prop shaft) will require a little more oil and if you filled it from the top you may want to recheck it. It takes a while to drain down. New style 11-14 greased shafts and oil bath gears not an issue when filling. |
Author: | EastTexasDucks [ Fri Jul 25, 2014 9:27 pm ] |
Ok this is a 2012. So should I refill it from the bottom or let her roll |
Author: | bayouboy [ Fri Jul 25, 2014 9:32 pm ] |
2012 your good to go my boy!! Wait! I said that a little premature my boy. Did you also grease the shafts? |
Author: | EastTexasDucks [ Sat Jul 26, 2014 10:13 am ] |
Yes sir, all greased up. Thanks for the help! |
