| stock gtr w/3 blade http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=55194 |
Page 1 of 2 |
| Author: | 62flint [ Mon Jul 28, 2014 8:32 pm ] |
| Post subject: | stock gtr w/3 blade |
I have a 1854 extreme with a stock gtr35 with a 3 blade prop. I get my best speed about 3500 rpm. If I trim up I pick up rpm but loose mph. This a 3 blade thing or will a 2 blade do the same. I was thinking more rpm more speed. But I am not trimming up a lot to loose bite. |
| Author: | lunacris [ Mon Jul 28, 2014 8:35 pm ] |
| Post subject: | Re: stock gtr w/3 blade |
most reviews from guys with the 3 blade say that modded motors run them better. you probably will get better performance from a 2 blade with your motor. did your motor come stock with it or did you request it? search it on here, theres a lot of info |
| Author: | basinhunter2012 [ Mon Jul 28, 2014 8:36 pm ] |
what is your speed? the new units with 3 blades have been running lower rpms but that sounds to low |
| Author: | 62flint [ Mon Jul 28, 2014 8:43 pm ] |
I am running 27 mph by my gps. But I am also carrying a light load. I have seen 28 mph. 3500-3600 rpm. trim up a little boat drops to 23-25 mph and 3800- 3900 rpm . old style lower unit. I am happy with performance. tickled shitless really for a stock rig. Add some weight and it drops to 22 mph fairly quick. Guess that is where some mods will help, just hate to spend The $$$$ right now |
| Author: | LA Prop [ Mon Jul 28, 2014 8:59 pm ] |
| Author: | 62flint [ Mon Jul 28, 2014 9:06 pm ] |
| Author: | baron von [ Tue Jul 29, 2014 6:17 am ] |
what hole are you running your trim in - I noticed that when i run mine in a higher trim hole I gain RPM also but loose top speed, but the engine seems not to be loaded or working as hard at 4100 (higher trim) than at 3700 RPMs (lower trim) |
| Author: | LA Prop [ Tue Jul 29, 2014 9:52 am ] |
| Author: | SirBacon [ Tue Jul 29, 2014 10:47 pm ] |
I have, roughly, the same results as you. 27mph at 37-3800. New lower unit and 3 blade on a 16-54 Extreme. This being on the 2nd from top. I can trim it higher and gain RPM but speed drops. |
| Author: | dcboy [ Sun Aug 03, 2014 5:46 pm ] |
It's seems to me you have a first series 3 blade pretty much too much wheel for a stock motor but all the new outdrive motor should have the new 3 blade. |
| Author: | debo [ Mon Aug 25, 2014 10:00 pm ] |
I got my motor in mid May. I'm running a 3 blade with the new lower on a 18' 50" custom boat running 27-28 mph @ 3600-3700 seems to be the sweet spot. Motor is stock. I ran a 2 blade yesterday and my boat ran 2 mph slower best speed were around 3900-4000. Vibration was much worse with the 2 blade. Needless to say the 3 blades back on. My hole shot was much worse with a load also. For my boat the 3 blade seem to perform the best. |
| Author: | BayouStateHunter [ Tue Aug 26, 2014 7:41 am ] |
Try the top hole. |
| Author: | AirFido [ Tue Aug 26, 2014 12:40 pm ] |
That's what she said |
| Author: | baron von [ Tue Aug 26, 2014 12:43 pm ] |
| Author: | baron von [ Tue Aug 26, 2014 12:44 pm ] |
I also think with the new lower unit and 3 blade the "power band" for a stock engine is at or around 3700 for best overall performance - no one is going to admit that yet, oh wait I just did. |
| Author: | LA Prop [ Thu Aug 28, 2014 1:24 am ] |
| Author: | ajverret [ Fri Aug 29, 2014 10:16 pm ] |
That's what I'm turning with my 2011 best speed is 29-30 and 3750 that's with a gator tail 2 blade and stage 1 motor |
| Author: | scarygary [ Sat Aug 30, 2014 5:23 pm ] |
I bought a new 1754 gator trax with a hunt deck. Put on a new gator tail. 3 blade prop that came with motor. 3 batteries. 12 gal gas deep water. 32 mph at 4720. Motor has a few mods added. Still tuning. |
| Author: | baron von [ Sat Aug 30, 2014 5:37 pm ] |
a "few" nods SG - please say more |
| Author: | Scary Gary [ Sat Aug 30, 2014 6:11 pm ] |
Sorry I had a business call and couldn't finish my post. I also bought a 12 3/4 dia hammer to try and with same load the speed was 31 mph at 4640. But a lot of vibration. Went back to the 3 blade. Now the motor that was on the new GT frame is on stand by while i run this motor I just rebuilt. The mods are heads, cam, rocker rollers , twin carbs, billet rods, pistons, and mm exhaust. It's a large boat and I was worried about hp. The hole shot is incrediable and top end is ok for a round chime. |
| Author: | AKA Freshwaterkilla [ Sat Aug 30, 2014 6:43 pm ] |
It sounds like a slow turd to me at those rpms Sent from my iPhone using |
| Author: | Scary Gary [ Sat Aug 30, 2014 6:58 pm ] |
| Author: | AKA Freshwaterkilla [ Sat Aug 30, 2014 7:28 pm ] |
| Author: | Scary Gary [ Sat Aug 30, 2014 7:56 pm ] |
| Author: | gonepecan [ Tue Sep 16, 2014 9:29 am ] |
My stock gt turns 3500 with the 3 blade. I brought it to baggy in houma. He is going to take an inch of pitch out so my rpm's go up. Will let you know how it does when I get it back. |
| Author: | BDUBYA [ Tue Sep 16, 2014 9:45 am ] |
I bet youll get more rpm completely out of the water but less speed. Gotta find that happy spot. |
| Author: | LA Prop [ Mon Sep 22, 2014 3:45 pm ] |
Gt has the 10 pitch it's a much better 3 blade than the old ones more people are liking them and have had better luck with the 10 pitch |
| Author: | mizzippi jb [ Mon Sep 22, 2014 4:30 pm ] |
I drove my buddy's new gtr with the new lu and a 3 blade. The skeg looks like there's no way to bend it (no cutouts for a tab and thick as shit) and that fucker will push you out of the boat with the tiller torque. Gonna let him try a 2 blade I have to see if it works better. If now I may make him some sort of bolt on tab that will lessen the torque |
| Author: | msm8281 [ Mon Sep 22, 2014 4:32 pm ] |
I was turning 4100 with a stock motor and 10 pitch 3 blade. 4450 with Mikuni and stainless works exhaust now. |
| Author: | odass [ Mon Sep 22, 2014 4:55 pm ] |
After I put my carb on I can get up to about 28mph empty. But if I run it hard loaded it gets hot and starts detonating really bad. Think I need to open my exhaust. Maybe that will help. Soon as teal season is over it's stage 3 time... |
| Author: | mizzippi jb [ Mon Sep 22, 2014 5:13 pm ] |
How's the tiller torque on yalls new ones? I told my buddy to call gt and ask them. I'm used to driving mine with 2 fingers. His was kicking my ass |
| Author: | SCmudder7071 [ Mon Sep 22, 2014 6:34 pm ] |
| Author: | LA Prop [ Mon Sep 22, 2014 6:37 pm ] |
| Author: | tyler_johnson [ Mon Sep 22, 2014 6:48 pm ] |
I have a stage 2, and the older lower unit and I can hit 30-32 with 2 blade and 4 people and stay a steady 31 with the same load with the 3 blade(10 pitch). But my boat turns and is easier to control with the 2 blade Sent from my XT907 using Tapatalk |
| Author: | Ben_ huntin [ Mon Sep 22, 2014 7:09 pm ] |
| Author: | tyler_johnson [ Mon Sep 22, 2014 7:11 pm ] |
Yeah my 3 blade is my spare or for long runs Sent from my XT907 using Tapatalk |
| Author: | LA Prop [ Mon Sep 22, 2014 7:54 pm ] |
| Author: | odass [ Tue Sep 23, 2014 7:11 am ] |
| Author: | pearl river outlaw [ Tue Sep 23, 2014 7:38 am ] |
| Author: | mizzippi jb [ Tue Sep 23, 2014 9:50 am ] |
| Page 1 of 2 | All times are UTC - 6 hours |
