| Gen III PD Props http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=55615 |
Page 1 of 2 |
| Author: | Woodiebuster [ Mon Aug 11, 2014 12:52 am ] |
| Post subject: | Gen III PD Props |
Has anyone played with some new props for these motors yet? Seems like us with smaller/lighter boats could get more out of our rig with a bigger prop. My rig runs its best at 45-4600 rpms empty and don't drop off much at all with a 3-4 man load. When I mod my motor I'll have to have more prop to do much |
| Author: | Will [ Mon Aug 11, 2014 4:26 am ] |
| Post subject: | Re: Gen III PD Props |
I've been waiting for someone to try a regular old outboard prop for open water running. 13spline 7/8 shaft LH |
| Author: | tchauvin [ Mon Aug 11, 2014 5:05 am ] |
^^^no shit...i seen some mud boats with outoard lower units used that were very fast. Seen a stock 36 bolted to a 60 merc lower unit run 30 easy. |
| Author: | tchauvin [ Mon Aug 11, 2014 5:18 am ] |
| Author: | LA Prop [ Mon Aug 11, 2014 5:37 am ] |
I found some chopper props that would really work for y'all needs problem is they are almost 400$ for a test prop I don't know many people with pockets that deep for a maybe They left hand and have a variety of pitches. If u wanna send me your prop I can pitch it up for ya and see how much more you'll gain .. I pitched an old gen 2. 3 blade to a 20 pitch for Mac and he could turn it well |
| Author: | tchauvin [ Mon Aug 11, 2014 5:56 am ] |
| Author: | LA Prop [ Mon Aug 11, 2014 6:00 am ] |
Is yours the 15 pitch |
| Author: | tchauvin [ Mon Aug 11, 2014 6:21 am ] |
| Author: | LA Prop [ Mon Aug 11, 2014 6:28 am ] |
| Author: | tchauvin [ Mon Aug 11, 2014 6:34 am ] |
| Author: | LA Prop [ Mon Aug 11, 2014 6:42 am ] |
I have an 11" 3 blade I pitch up to a 20 and he can hit the revlimiter with it adding cup today see if that helps bind it a little |
| Author: | tchauvin [ Mon Aug 11, 2014 6:47 am ] |
Let me know how it runs. I know this one dont run very well speed wise. It looks to me about ~2mph slower as opposed to the GEN2 lower and prop with same mods.... I think for all around usage and how i use a boat i would like the new gear. It grew on me....The power to eat though float is unreal and i always seem to have a good load with me. Typically have 3-4 bowifishing and 2-3 hunting. I think that gear with a little better engine. Or an engine that can turn 5000 safely would be a good combo. |
| Author: | LA Prop [ Mon Aug 11, 2014 8:29 am ] |
| Author: | 50fps [ Mon Aug 11, 2014 1:49 pm ] |
Has anyone tried a Stumpy designed prop on the Gen 3 yet? |
| Author: | tchauvin [ Mon Aug 11, 2014 2:41 pm ] |
Not sure, but have tried a 2 blade PD prop pitched up to like 20'' and it didnt work well. 2.0-1 ratio blew right threw it....cavitated bad. |
| Author: | LA Prop [ Tue Aug 12, 2014 2:59 am ] |
| Author: | tchauvin [ Tue Aug 12, 2014 6:09 am ] |
| Author: | Will [ Tue Aug 12, 2014 3:27 pm ] |
What about something like this? |
| Author: | Will [ Tue Aug 12, 2014 3:30 pm ] |
| Author: | MarshJB [ Tue Aug 12, 2014 3:41 pm ] |
Those are all right hand props. |
| Author: | msm8281 [ Tue Aug 12, 2014 3:49 pm ] |
Put it on backwards and use full power reverse. |
| Author: | MarshJB [ Tue Aug 12, 2014 3:53 pm ] |
| Author: | msm8281 [ Tue Aug 12, 2014 3:54 pm ] |
Lmao...did it work? |
| Author: | MarshJB [ Tue Aug 12, 2014 4:06 pm ] |
Yes, but can't keep it trimmed down, and filled the back of my boat with 2 inches of mud. |
| Author: | bayouboy [ Tue Aug 12, 2014 4:15 pm ] |
| Author: | MarshJB [ Tue Aug 12, 2014 4:21 pm ] |
I actually had some on my now non existent Facebook account. I think my gf may have them on her phone. |
| Author: | banded-mallard [ Wed Aug 13, 2014 5:18 am ] |
| Author: | Will [ Wed Aug 13, 2014 5:32 am ] |
| Author: | MarshJB [ Wed Aug 13, 2014 5:38 am ] |
| Author: | Will [ Wed Aug 13, 2014 5:48 am ] |
| Author: | THE TANK [ Thu Aug 14, 2014 3:16 pm ] |
Get you some of that! LA prop can make it happen......20p GD prop and still hitting the rev we need more cup! |
| Author: | MarshJB [ Thu Aug 14, 2014 5:18 pm ] |
What's your rev limit? If you're telling me you are turning it 4700 then what's the ratio of the LU. What speed btw? |
| Author: | JLACOUR [ Thu Aug 14, 2014 5:37 pm ] |
| Author: | JLACOUR [ Thu Aug 14, 2014 5:38 pm ] |
| Author: | MarshJB [ Thu Aug 14, 2014 5:44 pm ] |
4700, 1.5 ratio, 20p prop, factoring in 10% slip which is conservative for a surface piercing propellor equates to 53.4 mph. |
| Author: | MarshJB [ Thu Aug 14, 2014 5:45 pm ] |
2:1 ratio equates to around 40mph. |
| Author: | OwenDickeson [ Thu Aug 14, 2014 6:01 pm ] |
2:1 is what he has, and I believe that is an 11" prop |
| Author: | MarshJB [ Thu Aug 14, 2014 6:02 pm ] |
Ok, so factoring in more slip puts him at 35-36mph. |
| Author: | OwenDickeson [ Thu Aug 14, 2014 6:03 pm ] |
I think he is running around 34 |
| Author: | MarshJB [ Thu Aug 14, 2014 6:06 pm ] |
That puts him at 23% slip, a little more cup should do the trick. |
| Page 1 of 2 | All times are UTC - 6 hours |
