| ceased prop help http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=57639 |
| Author: | jordie1792 [ Tue Oct 28, 2014 9:25 pm ] |
| Post subject: | ceased prop help |
Ive tried everything to remove a stuck prop and I cant get it to budge. let soak in pb.Even made a tool and bent it. Help! |
| Author: | JLACOUR [ Tue Oct 28, 2014 9:26 pm ] |
| Post subject: | Re: ceased prop help |
What's it on? |
| Author: | SwampDonkey1 [ Tue Oct 28, 2014 9:55 pm ] |
Cheater pipe on a big pipe wrench, Cheater pipe on a big cresent on the jam nut... |
| Author: | jordie1792 [ Wed Oct 29, 2014 4:27 am ] |
On a 20hp Honda beaver tail and done tried that swamp donkey. Still wont budge |
| Author: | Will [ Wed Oct 29, 2014 5:03 am ] |
Cut it off with a cutting disk (not grinding disk) and pop it with a hammer and chisel, you're not the only one. viewtopic.php?f=41&t=50418 |
| Author: | rhock19 [ Wed Oct 29, 2014 5:07 am ] |
Did u try torching it? |
| Author: | huck Finn [ Wed Oct 29, 2014 6:31 am ] |
If all fails. , cut it almost to the threads like stated above , then apply a good amount of never seize before new install. , then periodically loosen prop and reapply never seize thruout the year. A good wire brush cleaning to the threads before applying never seize won't hurt either . H Finn |
| Author: | dguidry [ Wed Oct 29, 2014 6:49 am ] |
Seized. |
| Author: | jordie1792 [ Wed Oct 29, 2014 8:56 pm ] |
Haven't tried torching it yet. That was gonna be my last option before taking a metabo to it. I work at a machine/fab shop. I can get it off just wanted some input on what every one else has done |
| Author: | jordie1792 [ Fri Oct 31, 2014 8:11 am ] |
Well after two broke pipe wrenches and grinding down a wrench and two cans of pb blaster plus 2 ten foot sticks of cheater pipe. I got the prop off have to re thread the shaft. Somebody put lock tight on it.... I added plenty of anti seize but I got her goin again |
| Author: | bpgast [ Sat Nov 01, 2014 1:50 am ] |
| Author: | SwampDonkey1 [ Wed Nov 05, 2014 10:10 am ] |
