Has anyone added cup to their prop
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=57976
Author:  banded-mallard [ Wed Nov 12, 2014 11:48 am ]
Post subject:  Has anyone added cup to their prop
Man I'm searching threads and can't find anything. Was wondering if anyone has tried to add cup to a prop. I'm not interested in how it performs in the mud. This would strickly be for open deep water runs. Trying to see if I can get a little more on top for some long runs.
Author:  butternut [ Wed Nov 12, 2014 12:10 pm ]
Post subject:  Re: Has anyone added cup to their prop
Ask La prop.
Author:  Zeek569 [ Wed Nov 12, 2014 12:36 pm ]
My experince the more pitch/cup you put the more top end you loose
Author:  dguidry [ Wed Nov 12, 2014 12:57 pm ]
More pitch= better in mud = less top end speed
Just had my prop reworked to build up and add little pitch. Lost top end but pulls like a tank.
Vibration increased a bit too. Gonna have it reworked to take out some pitch to happy compromise.
Author:  btmannin [ Wed Nov 12, 2014 2:12 pm ]
Author:  dguidry [ Wed Nov 12, 2014 2:22 pm ]
Author:  btmannin [ Wed Nov 12, 2014 3:28 pm ]
Author:  calphil [ Wed Nov 12, 2014 5:32 pm ]
Author:  bayouboy [ Wed Nov 12, 2014 6:28 pm ]
I re-cup them all the time and I also rebalance. They are great for getting the grunt and hole shot back, but they do lack on the top end a couple mph.
Author:  DmaxHunter [ Wed Nov 12, 2014 7:25 pm ]
I just la prop add cup and pitch to a damaged big blade, fast turn around. Prop looks great, haven't run it as blind is being built.
Author:  banded-mallard [ Wed Nov 12, 2014 7:48 pm ]
Don't need anymore hole shots with this torque monster. Looking to give a little low end for some top.
Author:  calphil [ Wed Nov 12, 2014 8:38 pm ]
I'd say repitch ,
Author:  StevefromAR [ Wed Dec 03, 2014 7:54 pm ]
I've recupped outboard props with a 3 pound shop hammer-lay the blade over the ball of your trailer hitch. Rebalance by laying the prop hub down on a flat surface and measure the distance from each blade to the surface. Works surprisingly well on stainless and aluminum. Don't see why I can't do my long tail prop but haven't tried it yet.
Author:  Howdy [ Wed Dec 03, 2014 8:02 pm ]
I'd imagine you would a big Damn hammer to bend mm prop
Author:  pokey79 [ Wed Dec 03, 2014 8:23 pm ]
viewtopic.php?f=41&t=49758
theoretically adding heavy cup is like adding 1'' of pitch
im about to send another one to baggy to get balanced and had heavy cup only!
Author:  duckduckboom [ Wed Dec 03, 2014 8:59 pm ]
Author:  Bug [ Thu Dec 04, 2014 7:45 pm ]
Author:  cupped up [ Thu Dec 04, 2014 9:54 pm ]
Author:  Waterfowl_Widowmaker [ Fri Dec 05, 2014 10:38 am ]
I recupped mine I welded around the edge and just kept building it up then just grinded and sanded it smooth. Just got to try to make it even on both side and balance it out. Mine worked great and didn't vibrate a bit and holds up good I've been running it for a while now and can't complain.
Author:  LA Prop [ Fri Dec 05, 2014 3:24 pm ]
adding pitch will not make it grab harder in the mud adding cup will like bayou boy said itll give u the low end grunt but youll loose a little on the top end
dguidry i added alot of cup to yours thinking your mods would be enough to swing it ill take some out and rebalance it for u as soon as i get it send it with tony or ryan if u can
Author:  LA Prop [ Fri Dec 05, 2014 3:25 pm ]
Author:  pooldoo73 [ Thu Dec 18, 2014 12:06 pm ]
U need to look into a different prop. A couple guys have had some open water props that were impressive on speed.
Think chopper prop, not mm prop.
Author:  pnut [ Thu Dec 18, 2014 7:11 pm ]
Author:  dguidry [ Thu Dec 18, 2014 8:33 pm ]
Author:  LA Prop [ Sat Dec 20, 2014 5:13 am ]
They do not make them the guys were buying a chopper and broaching an outboard prop I think hill was selling them...
Also I've been adding a lil pitch to some props that r a little worn and we've been having good results but for nodded motors never tried anything like that on a stocker.
Also I've been noticing that the gtr 2 blade with light cupping is hard to turn even with a modded motor
Author:  ajverret [ Sat Dec 20, 2014 6:37 am ]
I may come swing by in a couple of weeks when I get in from offshore to see if can straighten one of me ears up it's got a slight bend about an 1 1/2" from the tip
Author:  LA Prop [ Sat Dec 20, 2014 8:57 am ]
Roger that pal I'll be waiting
Author:  Buddy [ Sat Dec 20, 2014 9:04 am ]
Author:  banded-mallard [ Sun Dec 21, 2014 8:21 am ]
Got prop back from Baggy. Wanted to add 3" of pitch. When it arrived, the paper work said 15p but the prop has 16p on it. Can't get him till tomorrow to actually find out what's the deal. So I haven't mounted it yet to go run.
Author:  LA Prop [ Wed Dec 24, 2014 2:52 am ]
its prolly 15" of blade pitch and 16" total with the cup
