i have a 35 mudbuddy i put the 42mm mikuni gutted the stock exhaust and just sent my heads off to the boat doctor to get worked. now my question is wouldnt that make it a 4400 witch comes with the 48 tooth lower gear should i change mine or leave it a 50 tooth
_________________ 1648 G3 2013 mudbuddy 35
Sun Jan 04, 2015 7:40 pm
Barroll
Joined: Fri Jan 15, 2010 10:19 am Posts: 932 Location: Georgia
Re: mudbuddy lower gear change opinion
Run it with a hunt load.....See where you are....
I ran a 35 with heads carb, exhaust on a 1854 with a 50 tooth bottom and liked the bottom end and load carrying. You may like the lower gear
_________________ 1848 Prodigy 35 GTR
Sun Jan 04, 2015 8:17 pm
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
Agree with Barrol.....run it first to see where your at with your most common loading. Then gear it accordingly to get in your target rpm range.
