Lower unit
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=60500
Author:  T coon [ Sun Mar 01, 2015 4:46 pm ]
Post subject:  Lower unit
Hey yall this is my first post on here and i have a ? I have a 2015 gator tail all stock but the new throttle lever like on the efi models and was doing some maintenance the motor has76.5 hours when i pulled the phillip head screw in order to grease the end near the prop they had water come out every time i pump the grease gun for bout 8 pumps wondering if seals are bad already?? I always cut whatever grass moss string or whatever seams to get wrapped behind the prop when i put it on the trailer or is this normal?? Also greased the othor end near the belt that return had just grease come out thanks
Author:  debo [ Wed Mar 04, 2015 3:36 pm ]
Post subject:  Re: Lower unit
I have the new lower unit also. Seems to be common on the new lowers. I haven't had any issues yet also talked to gatortail. They said it's nothing to be alarmed over. I have roughly around 90 hrs, motors about 9 months old.
Author:  OwenDickeson [ Wed Mar 04, 2015 4:12 pm ]
You need to be adding new grease to the rear zerk every 15 hours.
Author:  SCmudder7071 [ Wed Mar 04, 2015 4:27 pm ]
Yup^^^
Author:  Dbishop311 [ Wed Mar 04, 2015 9:40 pm ]
New lower unit here and I have not had water or and milky grease come out. Grease mine every 10 hours. Hopefully ai dont run into this
Author:  bull4202 [ Thu Mar 05, 2015 5:41 am ]
what kinda grease yall using? or better yet does it matter what kind you use as long as there is grease in the shaft? I got some free stuff at work is why im wondering.
Author:  debo [ Thu Mar 05, 2015 5:51 am ]
I grease both sides every 15 hours, sometimes before depends how hard I run it. I use the grease that gatortails sells. I think it schaeffer's grease not sure which one, I would have to look. It's not much water, first 3 - 4 pumps clear water comes out.
Author:  Dbishop311 [ Thu Mar 05, 2015 6:02 am ]
Pretty sure you have to use a certain lithium base grease. Of thats what Gatortail tells you. Shaeferrs comes with a new Gatortail but amsoil grease works too
Author:  Dbishop311 [ Thu Mar 05, 2015 6:03 am ]
Shaefffer 238 Moly Supreme
Author:  MaXXis85 [ Thu Mar 05, 2015 7:26 am ]
They switch grease to suit their needs. Any extreme pressure grease will work in the bearings.
Author:  T coon [ Fri Mar 06, 2015 8:06 pm ]
Had trash holding seal open ended up bringing it to Gatortail they got it all straight everything is ok the service is awesome real good down to earth guyes over there i was super satisified
Author:  Russ [ Sat Mar 07, 2015 10:50 am ]
So its ok to have water coming out of the NEW lower when you add grease? There's not one thing about that concept that seems OK to me. Maybe one of you gt guys can explain why having water in there is ok. It seems as though from the OP's experience, it was not a normal thing, as a seal was not operating properly.
