It is currently Tue Dec 23, 2025 10:43 am
Reply to topic  [ 4 posts ]
 help knowing if I have the correct prop!
Post help knowing if I have the correct prop!
I need help knowing if I should put these props on. They are slightly different than the one I'm using. When I bought the motor he gave me three props. The one in the middle is the one I've been running. The one on left and right are slightly bigger. And have a different center. They will start to go on the shaft but if I wanted to get them all the way I'd have to hit with a mallet or something. How do I know if I can put them on or not? Thanks
Sat Mar 14, 2015 12:22 pm
Post Re: help knowing if I have the correct prop!
Going on a 23 HP mud buddy sd
Sat Mar 14, 2015 12:46 pm
Run them and find out witch runs better
1852 Dfou custom 35gtr
Sat Mar 14, 2015 3:23 pm
Double banded . is it normal that the prop would have to be forced on the shaft? The one on there now slides right on...
Sat Mar 14, 2015 4:50 pm
