shotgunwilly1117
Joined: Wed Aug 04, 2010 3:19 pm Posts: 345 Location: Tallahassee, Fl
 Copperhead bearings
Running on a budget. I got a bad bearing on one end of my shaft of an 18. I've got the shaft housing off but haven't pulled the shaft out. Anyone know if I can find bearings that will work from a local parts store?
Mon Mar 23, 2015 1:08 pm |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
 Re: Copperhead bearings
Find a place that specializes in bearings and they should be able to find one.
Or call copperhead and see how much they are.
Sent from my beeper
Mon Mar 23, 2015 1:12 pm |
shotgunwilly1117
I was going to call me once I know which one is bad but I didn't know if anyone had some cheap source where they get equivalent bearings
Mon Mar 23, 2015 1:27 pm |
baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
most bearings & seals have numbers stamped in them - a good parts guy can match
_________________ that's going itch when it dries
Mon Mar 23, 2015 1:35 pm |
Mag10
Joined: Wed Jan 14, 2009 12:31 pm Posts: 342 Location: Faribault, Mn
Any NAPA or Fastenal should be able to get it for you
Mon Mar 23, 2015 7:06 pm |
littleO
Joined: Fri Jan 09, 2015 10:32 pm Posts: 34 Location: delafield wisconsin
is it a older one with out the snake head cut out ?
_________________ 1236 Appleby 1436 Alumacraft Go-devil 5hp crawfish 1452 Delhi Alumcraft waterfouler 16 beavertail 35hp sd
viewtopic.php?f=17&t=59558
Mon Mar 23, 2015 8:16 pm |
shotgunwilly1117
Yeah it is a 2012. I pumped it full of grease and it quieted down although if you spin it real slow you can feel a rough part. I may just ride it until grease doesn't help it.
Tue Mar 24, 2015 12:13 pm |
mudxxed
Joined: Thu Sep 05, 2013 4:46 pm Posts: 1398 Location: SE Bama
Not 100% sure how their designed, but if that bearing blows into a million pieces your shaft will likely go as well.
_________________ 1651 Excel/ 35 MB HD: little of dis, little of dat
Tue Mar 24, 2015 12:26 pm |
SETx Longtail
Buying just the bearing probably won't cost any more than the seals and grease. I would suggest replacing it before it fails to save the shaft and potentially the housing. Fresh seals and grease while you're there....
_________________ #CFFITR
Tue Mar 24, 2015 6:37 pm |
Will B Free
Where can I get seals? I need them for my trailer. The only "seals" I can find are bearing buddies and I don't want those. I thought this would be an easy find but apparently not
Thu Mar 26, 2015 12:18 pm |
cb5331
Bearing buddy's are not seals. Just a cover. Are you looking for the plain metal caps? I don't really understand why you'd want those over bearing buddies, as you'd have to knock the cap off and pack by hand every time your hub needed grease.
The only real seal on most traditional style hubs is on the inside or backside of the hub (axle side). There isn't a seal on the spindle side, just the race, bearing, and crown nut on top of the bearing, then the cover, and most people would just use a bearing buddy or something similar there.
Thu Mar 26, 2015 12:24 pm |
Will B Free
Im looking for the plain metal caps. I want to put that on instead of bearings buddies.
Fri Mar 27, 2015 8:02 am |
cb5331
Tractor supply has them.
Fri Mar 27, 2015 8:08 am |
krazo
Joined: Thu Sep 06, 2012 8:44 pm Posts: 667 Location: SE Bama
Bearings and seals are too cheap to run bad ones. If you run bad bearings you will wear you shaft and have to replace a shaft too. Any parts house will have them. Change them all while your in there.
_________________ 1754 prodigy- stage 2 GTR
Sun Mar 29, 2015 7:36 pm |
