DUCKSBANE
12x13 cleaver prop vibration question.
Its a 12 x 13 with heavy tip curl. The prop does a pretty good job with my stage 1 setup overall and achieved my main goal of getting the rpms down. They are a little lower than I wanted but its not bad. With a decent load its got its best speeds at 3900 rpms. The problem is at low RPM while in gear it raddles the shit out of the engine. Looking at the carb it looks like it is just going to fly off at any minute. Yesterday I lost 2 screws from the motor and this has never happened before.
Two questions???
1. is it the heavy tip curl thats causing the vibration??
2. If it is the tip curl, could I just pull it and bang some of it out or do they need to be heated?
Thanks
_________________ 1860 Phowler Extreme W/ stage 1 36 PD
Sun Nov 22, 2009 5:40 am |
basinhunter
Joined: Tue Jan 13, 2009 6:22 pm Posts: 1642 Location: Morgan City, LA
Re: 12x13 cleaver prop vibration question.
It's prolly out of balance
_________________ Pro Drive m'fers
Mon Nov 23, 2009 8:50 am |
DUCKSBANE
Mon Nov 23, 2009 9:31 am |
basinhunter
I ran a outta balance prop and that thing would rattle your teeth lol
Let us know how it runs when you get it back
Mon Nov 23, 2009 9:34 am |
SP
Is this prop in balance! You want to talk about rattling the engine back to the ramp! I ordered the Hopkins Cleaver 12x13 to replace the stock in picture, and my RPMs went up and I lost 2 MPH. I sent it back to Glen he is probably going to add some pitch to it. I wasn't impressed though. I put a new stock back on, RPM's stayed the same I gained the 2mph back.
Tue Nov 24, 2009 10:15 pm |
hotdognjo
Joined: Mon Jan 26, 2009 10:04 am Posts: 480 Location: Laplace, LA
Man, what you hit with that prop?
_________________ 1754 PD Center Console, 60 Yammy, w jack plate
Wed Nov 25, 2009 2:47 pm |
DUCKSBANE
I slung a blade just like that 2 miles from the launch. It was a half day push back to the ramp. I watched the blade cut across the marsh and cut a path through the cat tails 100 yards away I assume it was a defect in the metal. oh and it was hell getting the prop off without the 2nd blade to grab.
Wed Nov 25, 2009 3:21 pm |
SP
I actually think it was a defective prop. I didn't hit anything. Something could have clipped the side f the prop just perfect, but normally you would feel it in the bow first. I was running WOT through thick veg, and wham! I couldn't believe it when I trimmed the motor up. I was able to actually limp back tot he ramp, but i thought I was going to lose every bolt on the engine!
Wed Nov 25, 2009 5:40 pm |
dead animal
i've slung a blade off several props, from differant manufactures. they all make a bad one now and again, the differance is what the dealer does to make it right.
i had 4 hopkins do that, tough luck from hopkins.
had 1 pd prop do that, got a new prop from pd.
guess what prop i run now?
Sun Nov 29, 2009 9:33 pm |
DUCKSBANE
Mon Nov 30, 2009 7:12 am |
DUCKSBANE
It was out of balance. Its all good now.
Sun Dec 13, 2009 5:55 pm |
basinhunter
Tue Dec 22, 2009 9:03 am |
