Best place to purchase Prop
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=61435
Author:  badhen [ Thu Apr 23, 2015 8:50 am ]
Post subject:  Best place to purchase Prop
I need to purchase a new prop for my '12 Prodrive 36hp. I see that you can purchase new ones from PD, but are there any other options available for "aftermarket" props? Any other advice or things I should consider before buying one is appreciated!
Author:  GDSArgo [ Thu Apr 23, 2015 9:29 am ]
Post subject:  Re: Best place to purchase Prop
If you order one from Prodrive talk to your local prop guy get it sent direct. That way he can do a little needed TLC on it right from the get go.
Sent from the company's iPad while at work
Author:  BlueShamu [ Thu Apr 23, 2015 2:00 pm ]
There is the Cleaver...which in and of itself, is not a bad prop. But, just anticipate sending it somewhere to get the tapered hub machined down correctly....and then balanced. Hopkins does a less than desirable job on this which has resulted in some negative (and costly) results for some folks.
The 27 HP 3 blade is also an option which I have had good results with load carrying and speed.
Ultimately, whatever you get will probably have to be fine-tuned to suit your set-up, wants and needs....or get different props for different conditions.
Author:  BlueShamu [ Fri Apr 24, 2015 8:02 pm ]
Then, there's this contraption...
Author:  brickgw [ Fri Apr 24, 2015 8:08 pm ]
Looks like something out of a Friday the 13th movie!
Author:  BlueShamu [ Fri Apr 24, 2015 10:23 pm ]
And yes.....it is threaded on the shaft with a tapered bushing. No room for the prop nut, though.
