| Mudbuddy mini http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=63571 |
| Author: | Motodill442 [ Mon Sep 07, 2015 1:06 pm ] |
| Post subject: | Mudbuddy mini |
I just purchased a 23 hp mudbuddy mini and it needs a new prop. It has a 11x10 on it now but I see mudbuddy says they come with big blades now. What prop are you guys with minis running? |
| Author: | Motodill442 [ Mon Sep 07, 2015 1:10 pm ] |
| Post subject: | Re: Mudbuddy mini |
Forgot to add it has carb and exhaust. |
| Author: | Flounder [ Tue Sep 08, 2015 9:10 am ] |
depends on what your gearing is. if you have 38/52 gearing i would go big blade if you have 34/50 I would go 11x10. It all depends on what rpms you can turn. Each boat and load is different with 34/52 with a mostly stock 23 I could turn a BB around 4000 rpms with new prop. |
| Author: | Flounder [ Tue Sep 08, 2015 9:22 am ] |
correction minis are smaller than an HD and biggest sprocket that can be used in a mini is a 50 tooth if you are not turning over 4300 with a worn prop I would stick with the 11x10 |
