| Stuck prop http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=63823 |
| Author: | Tucker1445 [ Tue Sep 22, 2015 8:48 pm ] |
| Post subject: | Stuck prop |
I'm trying to get this old prop off and get my new prop on. Iv'e used half a can of WD40 with no luck. I tried heating in moderation with no luck. I've backed off the net closest to the seal housing thinking that may help but not so. My next idea is to use a pipe wrench on the blades. Any other ideas or trucks that have worked for you? Thanks. Sent from my iPhone using Tapatalk |
| Author: | SETx Longtail [ Tue Sep 22, 2015 9:03 pm ] |
| Post subject: | Re: Stuck prop |
36" pipe wrench open facing the prop. Jam up the shaft so it won't turn and then pull on it. Don't bounce or hit it. Just a steady hard pull and it should come loose. |
| Author: | Russ [ Tue Sep 22, 2015 9:04 pm ] |
Use a pipe wrench on the hub, as it can grab it without being on the blades. Put a crescent on the nut on the nut so it'll hold the shaft. May need a couple cheater pipes to get enough leverage. |
| Author: | Tucker1445 [ Tue Sep 22, 2015 9:25 pm ] |
Thanks for the replies. I have rebar wedged in the u joint so it won't spin. Sent from my iPhone using Tapatalk |
| Author: | BlueShamu [ Tue Sep 22, 2015 10:05 pm ] |
WD-40 isn't what you need. Get some penetrating oil. Liquid Wrench, Knock'er Loose or what I like is PB Blaster. Soak it down early and often. Use a long 2 x 4 with a hole drilled through it to fit over your shaft. Slide the 2 x 4 between your blade flukes and give it a spin. 5' to 6' board gives you a lot of leverage. Good luck. Most liberals seem to suffer from the same mental condition....it's called stupidity! |
| Author: | BlueShamu [ Tue Sep 22, 2015 10:06 pm ] |
Oh....and Marine Grade Never Seize when you put it back on! Most liberals seem to suffer from the same mental condition....it's called stupidity! |
| Author: | JIMMY W [ Wed Sep 23, 2015 1:13 am ] |
Fucking Junk |
| Author: | banded-mallard [ Wed Sep 23, 2015 5:07 am ] |
| Author: | danimalw [ Wed Sep 23, 2015 7:29 am ] |
I made a 4' prop wrench out of 1.25"x1.25" square steel tubing (3/16" wall thickness) and couldn't get mine to budge.. and that was with Liquid Wrench (over a 2 wk period). Tried a torch as well. Ending up having to cut the prop off (needed replacement anyway). |
| Author: | Tucker1445 [ Wed Sep 23, 2015 7:56 am ] |
Thanks for the 2x4 idea and PB blaster I'll give that a try. As for marine grade anti seize, do auto stores carry that? |
| Author: | Russ [ Wed Sep 23, 2015 8:03 am ] |
Yep. |
| Author: | Anthonyaarnold [ Wed Sep 23, 2015 8:30 am ] |
I use an 18" pipe wrench with alot of elbow grease, it can sometimes be tricky to get the pipe wrench latched on there well. If your motor is on a boat strapping your tiller down to the floor of the boat also helps stabilize. Be careful using to much heat you'll ruin your seals. It will feel like its stuck and is not going to budge then it'll pop lose just got muscle it up real good. |
| Author: | BlueShamu [ Wed Sep 23, 2015 10:52 am ] |
| Author: | banded-mallard [ Wed Sep 23, 2015 11:14 am ] |
| Author: | BlueShamu [ Thu Sep 24, 2015 4:28 am ] |
The copper based is good for certain high heat applications. I personally don't use it on my engine. I use nickel based on engine components. I'd say why, but, I'm sure it would hijack the thread with a whole other debate. Sent from my iPhone using Tapatalk |
| Author: | JD145 [ Thu Sep 24, 2015 5:01 am ] |
| Author: | kibb [ Thu Sep 24, 2015 6:29 am ] |
Soak it with a 50/50 mix of ATF and acetone. Better penetrant than anything you can buy off of the shelf. |
| Author: | meterman3 [ Thu Sep 24, 2015 8:50 am ] |
Brake fluid and oil mix will do wonders give it 2-3 days |
| Author: | banded-mallard [ Thu Sep 24, 2015 9:36 am ] |
| Author: | Tucker1445 [ Thu Sep 24, 2015 4:28 pm ] |
Well low and behold the shaft had a crack in it... Prop is still on but shaft is junk at this point. |
| Author: | SETx Longtail [ Thu Sep 24, 2015 6:49 pm ] |
Better to find it now than to figure it out when your new prop is on the bottom of the river and you're calling SOS to a buddy |
| Author: | Tucker1445 [ Fri Sep 25, 2015 1:39 pm ] |
That's what I told my self when I gave my card number to get a new shaft |
| Author: | Johnny-O [ Tue Oct 20, 2015 12:32 pm ] |
What do you guy's use to stop the shaft from turning when trying to remove the prop? |
| Author: | kibb [ Tue Oct 20, 2015 4:50 pm ] |
Stick a piece of round bar through the u-joint |
| Author: | Johnny-O [ Wed Oct 21, 2015 6:51 am ] |
| Author: | cheniermudder [ Mon Oct 26, 2015 7:14 pm ] |
Did you get that prop off yet? If you haven't, you may have to pull the shaft (if possible with the prop on) and put it in a vice. My brother's longtail prop was a SOB to get off . He ended up building a tool that slipped over the hub and between the blades to get enough torque on the prop to break it loose. But that doesnt answer how to keep the shaft from turning...sorry, not much help there. |
| Author: | DutchBayouBoy [ Sun Nov 01, 2015 12:23 pm ] |
I always used a old lawnmower blade an a cheater pipe of the 6' kind... an I put a stainless rod into the hole in the clutch where the shaft leaves the bottom of motor (prodrive)... An always use never sieze, I keep mine in my boat along with the company issued 33, and tiewraps! |
| Author: | SALTYDUCK [ Wed Dec 09, 2015 8:13 pm ] |
. Sent from my SAMSUNG-SM-G870A using Tapatalk |
| Author: | cernigs23 [ Wed Feb 03, 2016 10:14 am ] |
I bent my drive shaft on a 35 swomp ls. Pulled the shaft put into a vice and could not break the prop free. Talked to Jake from backwater and he sent me a video of cutting the jam nut with a angle grinder. Right before you get to the threads take a chisel to the nut and break it lose. Prop spun right off. Be careful not to damage the threads on the shaft if you plan on reusing it. |
