| Water in Pro Drive Lower Unit Oil http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=64966 |
| Author: | Koots [ Sun Dec 13, 2015 5:26 pm ] |
| Post subject: | Water in Pro Drive Lower Unit Oil |
2007 Pro Drive Motor. I checked my lower unit oil after having it out just one time since the last oil change and the oil is milky. I am scheduled to head out on a trip this week and the low temps are forecast to be in the lower teens with highs in the 20's. I don't want to have things freeze and end up busting up things up in the lower unit. Any thoughts or suggestions that will allow me to still hunt this week? Thanks! |
| Author: | tchauvin [ Sun Dec 13, 2015 6:19 pm ] |
| Post subject: | Re: Water in Pro Drive Lower Unit Oil |
Mines was leaking in from the top of the input shaft on the lower unit...FYI... There is a 1/8" NPT hole for venting. I plugged it off and solved the issue. |
| Author: | Koots [ Sun Dec 13, 2015 7:15 pm ] |
tchauvin, what did you use to plug it? |
| Author: | Mudhole [ Mon Jan 04, 2016 12:25 pm ] |
Chances are the seal behind the prop is leaking! Quick and easy to replace |
| Author: | 75' forty [ Mon Jan 04, 2016 1:14 pm ] |
| Author: | Will [ Tue Jan 05, 2016 3:00 pm ] |
| Author: | tchauvin [ Tue Jan 05, 2016 3:03 pm ] |
| Author: | SwampnutzWi [ Fri Jan 22, 2016 2:30 am ] |
If it's a 2007 motor it might only have the 2 seals in nut looking thing behind the prop. Prodrive went to 3 seals in 2008 I think. U can get a new nut with 3 seals from Prodrive for $100 and send old back for $50 credit Sent from my iPhone using Tapatalk |
