| Trim on a mudbuddy 45 mag http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=65126 |
| Author: | Ole Boudreaux [ Fri Dec 25, 2015 1:46 pm ] |
| Post subject: | Trim on a mudbuddy 45 mag |
I get done hunting yesterday. Load up the boat trim the motor up. As I'm strapping down the boat the trim comes on and won't stop. I had to disconnect the battery to stop. Any ideas? Thanks happy holiday |
| Author: | flint87 [ Fri Dec 25, 2015 1:47 pm ] |
| Post subject: | Re: Trim on a mudbuddy 45 mag |
Gotta be in your trim switch Sent from my iPhone using Tapatalk |
| Author: | Ole Boudreaux [ Fri Dec 25, 2015 1:55 pm ] |
Can I get that part at napa? Or is it a mud buddy part only? |
| Author: | JD145 [ Fri Dec 25, 2015 2:01 pm ] |
You may be able to find one Somewhere else not sure, just call boatDR, he can fix you up. |
| Author: | lunacris [ Fri Dec 25, 2015 2:02 pm ] |
get the new style trim switch. i just upgraded mine, its wonderful. |
| Author: | Gunshinestate407 [ Fri Dec 25, 2015 2:29 pm ] |
Call boat dr. He had 2 new ones on my door step in a couple days. Sent from my iPhone using Tapatalk |
| Author: | flint87 [ Fri Dec 25, 2015 4:48 pm ] |
Disregard my last post. I just went full fucking retard talking about a clutch switch. This is why I drive a godevil... That and I'm too poor for a fancy mud buddy. Sent from my iPhone using Tapatalk |
| Author: | deadbird8 [ Sun Dec 27, 2015 3:05 pm ] |
| Author: | DmaxHunter [ Sun Dec 27, 2015 4:10 pm ] |
| Author: | Ole Boudreaux [ Thu Jan 07, 2016 6:30 pm ] |
Ok I changed trim switch,both relays, and both fuses. Still doesn't work. I think it's the motor. Can I buy a motor of eBay for 130$ or do I need to replace everything which would cost about 700$. Thanks for the help. |
| Author: | DmaxHunter [ Thu Jan 07, 2016 6:54 pm ] |
A couple have bought just the motor from Amazon or eBay, they posted the part number. Maybe someone will chime in |
| Author: | DENNYEDWARDS [ Sun Jan 17, 2016 10:13 am ] |
Amazon .com Mercury replacement trim motor. It is a direct replacement #809885A $122. Magnets came unglued in Motors case and locked it up in mine. Save your drive pin that goes in to pump, otherwise you may have to shorten the one that comes with motor. Will have to add fluid to resivour, because you will loose some when removing it from pump housing. They are self bleeding so you may hook it up to a battery, and run the cylinder up and down a few times to get air out of it. We clamp them up in vise and do this. Reverse pump wires to battery to reverse motor for up and down. Check res. level before installing back on motor. Saves much $$ over one from MB. |
| Author: | lunacris [ Sun Jan 17, 2016 11:44 am ] |
| Author: | lunacris [ Sun Jan 17, 2016 11:52 am ] |
| Author: | Migrator [ Sun Jan 17, 2016 2:34 pm ] |
Chris, is this the new mercury trim switch that comes on the HDR's? If so I like that switch. Should hold up much better than the old ones. Sent from my iPhone using Tapatalk |
| Author: | lunacris [ Sun Jan 17, 2016 2:52 pm ] |
it is.... i love how its recessed into the handle. the new clutch switch is also a big upgrade. |
| Author: | DmaxHunter [ Sun Jan 17, 2016 10:08 pm ] |
Luna are the parts online, or did you call and order |
| Author: | lunacris [ Mon Jan 18, 2016 8:18 am ] |
Andy hooked me up |
