It is currently Fri Dec 19, 2025 1:37 pm
[ 8 posts ] |
Water in Pro Drive Lower Unit Oil
Koots
2007 Pro Drive Motor. I checked my lower unit oil after having it out just one time since the last oil change and the oil is milky. I am scheduled to head out on a trip this week and the low temps are forecast to be in the lower teens with highs in the 20's. I don't want to have things freeze and end up busting up things up in the lower unit. Any thoughts or suggestions that will allow me to still hunt this week? Thanks!
| Sun Dec 13, 2015 5:26 pm |
tchauvin
Joined: Wed Jul 13, 2011 6:23 pm Posts: 4898 Location: Bourg LA
 Re: Water in Pro Drive Lower Unit Oil
Mines was leaking in from the top of the input shaft on the lower unit...FYI...
There is a 1/8" NPT hole for venting. I plugged it off and solved the issue.
| Sun Dec 13, 2015 6:19 pm |
Koots
tchauvin, what did you use to plug it?
| Sun Dec 13, 2015 7:15 pm |
Mudhole
Joined: Wed Jan 14, 2009 7:05 am Posts: 716 Location: NW La.
Chances are the seal behind the prop is leaking! Quick and easy to replace
_________________ "Gofer Everette?"
| Mon Jan 04, 2016 12:25 pm |
75' forty
| Mon Jan 04, 2016 1:14 pm |
Will
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Tue Jan 05, 2016 3:00 pm |
tchauvin
| Tue Jan 05, 2016 3:03 pm |
SwampnutzWi
Joined: Sat Aug 23, 2014 7:55 pm Posts: 100 Location: Central Wi
If it's a 2007 motor it might only have the 2 seals in nut looking thing behind the prop. Prodrive went to 3 seals in 2008 I think. U can get a new nut with 3 seals from Prodrive for $100 and send old back for $50 credit
| Fri Jan 22, 2016 2:30 am |
[ 8 posts ] |
