It is currently Mon Dec 15, 2025 3:47 am
Reply to topic  [ 6 posts ]
 GTR trim pin
Post GTR trim pin
Anyone know the diameter of the holes for the trim pin not anywhere near my boat right now and need to get another bolt to put through
Tue Feb 16, 2016 9:24 pm
Post Re: GTR trim pin
I think its 5/16" but possibly 3/8". Make sure you get a grade 8 bolt.
If you don't get it from GT you may have to special order it due to its length. A hardware store generally won't have that length.
Tue Feb 16, 2016 9:30 pm
Post GTR trim pin
We'll see it just so happens that I'm a mechanic in a big plant and just so happens that I'm at work right now may have to go rummage through :lol:
Tue Feb 16, 2016 9:53 pm
Post GTR trim pin
I'm just planning on using the bolt when trailering I'm gonna heat up one end and press it flat drill a hole and put a cotter pin through leave the one from GT in the bottom hole so when I get to the ramp I can just pull out the top pin
Tue Feb 16, 2016 9:56 pm
It's 3/8s, I got 3/8s metal dowel. Bent a 90* and drilled a hole for cotter pin. I leave the factory bolt in the bottom hole.
Tue Feb 16, 2016 10:12 pm
Ten foe appreciate the info
Tue Feb 16, 2016 10:31 pm
