It is currently Wed Dec 17, 2025 9:50 pm
[ 6 posts ] |
Ricerunner
Joined: Fri Sep 11, 2015 6:56 pm Posts: 887 Location: Summerville, SC
 GTR trim pin
Anyone know the diameter of the holes for the trim pin not anywhere near my boat right now and need to get another bolt to put through
| Tue Feb 16, 2016 9:24 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
 Re: GTR trim pin
I think its 5/16" but possibly 3/8". Make sure you get a grade 8 bolt.
If you don't get it from GT you may have to special order it due to its length. A hardware store generally won't have that length.
| Tue Feb 16, 2016 9:30 pm |
Ricerunner
 GTR trim pin
We'll see it just so happens that I'm a mechanic in a big plant and just so happens that I'm at work right now may have to go rummage through
| Tue Feb 16, 2016 9:53 pm |
Ricerunner
 GTR trim pin
I'm just planning on using the bolt when trailering I'm gonna heat up one end and press it flat drill a hole and put a cotter pin through leave the one from GT in the bottom hole so when I get to the ramp I can just pull out the top pin
| Tue Feb 16, 2016 9:56 pm |
TPerkins
Joined: Wed Jan 02, 2013 12:59 pm Posts: 1793 Location: Clear Lake, Tx
 Re: GTR trim pin
It's 3/8s, I got 3/8s metal dowel. Bent a 90* and drilled a hole for cotter pin. I leave the factory bolt in the bottom hole.
| Tue Feb 16, 2016 10:12 pm |
Ricerunner
 Re: GTR trim pin
Ten foe appreciate the info
| Tue Feb 16, 2016 10:31 pm |
[ 6 posts ] |
