GDSD Lower Bushing
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=65853
Author:  T-Bone [ Tue Feb 16, 2016 11:55 am ]
Post subject:  GDSD Lower Bushing
Checked for play by moving prop side to side and up and down, very little play. According to the Go devil manual you either have to use a special tool or reciprocating saw to cut it out. Once I removed the shaft the bushing just slid right out. No play at all. Question: Does that mean the bushing is worn and needs to be replaced or has anyone else been able to pull the bushing by hand?
Author:  flint87 [ Tue Feb 16, 2016 2:37 pm ]
Post subject:  Re: GDSD Lower Bushing
I haven't had one come out by hand. I would say replace it since its out. You're probly gona have to ream it when you put in a new one
Author:  SETx Longtail [ Tue Feb 16, 2016 6:38 pm ]
It's an interference fit. You press in the new bushing then size it to accept the shaft. Either use a bushing reaming tool or a good sharp 7/8" drill bit. The shaft should slide in smoothly and turn by hand with little resistance.
Author:  T-Bone [ Tue Feb 16, 2016 7:10 pm ]
I just slipped the bushing in the housing and it has some play until it is completely seated and then I don't feel any. It definitely looks like the bushing has been spinning in the housing.
Author:  flint87 [ Tue Feb 16, 2016 7:14 pm ]
Author:  Joe Guide [ Tue Feb 16, 2016 9:07 pm ]
Just be sure that you get ALL the items- you think you'll need- on your order at G.D.
