| GTR trim pin http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=65867 |
| Author: | Ricerunner [ Tue Feb 16, 2016 9:24 pm ] |
| Post subject: | GTR trim pin |
Anyone know the diameter of the holes for the trim pin not anywhere near my boat right now and need to get another bolt to put through |
| Author: | msm8281 [ Tue Feb 16, 2016 9:30 pm ] |
| Post subject: | Re: GTR trim pin |
I think its 5/16" but possibly 3/8". Make sure you get a grade 8 bolt. If you don't get it from GT you may have to special order it due to its length. A hardware store generally won't have that length. |
| Author: | Ricerunner [ Tue Feb 16, 2016 9:53 pm ] |
We'll see it just so happens that I'm a mechanic in a big plant and just so happens that I'm at work right now may have to go rummage through |
| Author: | Ricerunner [ Tue Feb 16, 2016 9:56 pm ] |
I'm just planning on using the bolt when trailering I'm gonna heat up one end and press it flat drill a hole and put a cotter pin through leave the one from GT in the bottom hole so when I get to the ramp I can just pull out the top pin |
| Author: | TPerkins [ Tue Feb 16, 2016 10:12 pm ] |
It's 3/8s, I got 3/8s metal dowel. Bent a 90* and drilled a hole for cotter pin. I leave the factory bolt in the bottom hole. Sent from my SM-G920V using Tapatalk |
| Author: | Ricerunner [ Tue Feb 16, 2016 10:31 pm ] |
Ten foe appreciate the info |
