It is currently Sat May 10, 2025 7:00 pm
Reply to topic  [ 25 posts ]
 Anyone ever had this happen?
Post Anyone ever had this happen?
Well i using using my motor yesterday morning running traps and i put the motor in reverse like i always do. Once the motor was locked in reverse, i gave it a little gas and all of a sudden i heard a pop and had no way to steer the boat. When i would turn the tiller, the top half of the motor would move but the lower unit would not move. Then this morning while messing with the motor, the lower unit fell off! Not sure if this had happened to anyone else but looking to see if anyone would know what broke. The gear on top of the lower unit has metal shavings all over it but not sure where its coming from. (Posted a video to demonstrate).
http://youtu.be/U9ogiF35xoA
18x40 skiff/35 hp GTR
Mon Feb 08, 2016 11:11 am
Post Re: Anyone ever had this happen?
Dammit man. That sucks
1854 Prodigy DPE Level 3 HDR
Mon Feb 08, 2016 11:20 am
Wow
Mon Feb 08, 2016 11:24 am
Yea im at a loss of how it happened.
Mon Feb 08, 2016 11:33 am
You broke all 6 of the tower bolts. Where is the spacer that is supposed to be in the housing? It sits in between the lu, and the reverse plate, big silver sleeve.
Mon Feb 08, 2016 11:57 am
It could still be in the other half of the motor. I would have to go look
Mon Feb 08, 2016 12:02 pm
Also suposed to be a teflon sleeve in the bottom and the top of the housing. Doesnt look like there's one in the bottom.
Mon Feb 08, 2016 12:05 pm
And just fyi, that powerheAd is not secured anymore. The plate its bolted to was bolted to the lower unit and thats what holds it all together. That powerhead can be knocked off pretty easily as it sits, so dont shake it around too much.
Mon Feb 08, 2016 12:07 pm
Mon Feb 08, 2016 12:26 pm
Mon Feb 08, 2016 1:07 pm
There aint anything holding it on. It will lift right off..
Mon Feb 08, 2016 1:18 pm
Mon Feb 08, 2016 1:33 pm
Duckt tape and zip ties
Mon Feb 08, 2016 1:57 pm
Mon Feb 08, 2016 2:13 pm
There is six (or four) bolts that go through the reverse plate, through the spacer (if it's there), and then into the lower unit. They're obviously no longer attached to the lower unit, so there is nothing holding the rest of that stuff together. Are the bolts broken off in the lower unit? Have you ever disassembled this thing? Look up in the tower housing, you should be able to see what's going on.
Mon Feb 08, 2016 5:09 pm
Never disassembled it but i can see 4 bolts that dont look broken from the top of the powerhead. The powerhead is just real loose. Gonna bring it to prodrive to have em look at. The spindle that drives lower unit seems stripped as well. Ill take a better look at it tonight
Mon Feb 08, 2016 5:20 pm
Strap all that shit to the tower housing before you take off down the road with it.
Mon Feb 08, 2016 5:26 pm
Gotcha. Bringing it to prodrive hopefully Wednesday to have em look at it.
Mon Feb 08, 2016 5:35 pm
Tue Feb 09, 2016 5:23 am
With the rough ass roads yall have there, I'd damn sure have a few straps holding that thing together.
Tue Feb 09, 2016 7:57 am
Tue Feb 09, 2016 11:08 am
What did you find out? curious.
Thu Feb 11, 2016 9:51 am
I guess its still broke or has this been fixed?
Mon Mar 07, 2016 5:50 am
It wont just fall off because of the spline adapter but yes, nothing be holding that bitch on but gravity now.
Mon Mar 07, 2016 9:04 am
Mon Mar 07, 2016 10:20 am
Users browsing this forum: No registered users and 150 guests
