It is currently Sat May 10, 2025 1:28 am
Reply to topic  [ 69 posts ]  Go to page 1, 2  Next
 Best new Mudmotors of 2016 lmao
Post Best new Mudmotors of 2016 lmao
But seriously how is this considerd a mudmotor no way I'd drag that thru the swamp,water cooled and outboard prop on lower unit,I'd go jet for same price as this.
Sent from my HTC One using Tapatalk
1654 GDSD 37efi.
Fri Jun 10, 2016 12:12 am
Post Re: Best new Mudmotors of 2016 lmao
Quote:
We had a lot of hunters from down under. All a bunch of great guys that liked to drink, root, and shoot shit in the dark. My kind of people.
Fri Jun 10, 2016 1:10 am
Could be keel cooled
17*38 Klibert 23GDLT
Fri Jun 24, 2016 9:51 am
I read that it has a closed loop cooling system
Sat Jun 25, 2016 11:57 am
If it is indeed closed loop, I'd like to get some info on it.
Mon Jul 18, 2016 5:00 am
Mon Jul 18, 2016 5:11 am
Well that's not very clear.
Mon Jul 18, 2016 5:12 am
Where did you see that pic? It won't enlarge so I can read it.
Mon Jul 18, 2016 5:14 am
Mon Jul 18, 2016 5:15 am
Not sure why it's not clear. Sorry.
Mon Jul 18, 2016 5:16 am
Can you post a link?
Mon Jul 18, 2016 8:01 pm
http://www.youtube.com/watch?v=Gr1Ee44CwDE&sns=em
I think it has potential. Competition and new ideas are a good thing.
Mon Jul 18, 2016 8:03 pm
Mon Jul 18, 2016 8:13 pm
This is what I gather from the short video.
Pros:
Really do like the concept.
Outboard engine rather than a f'n lawnmower engine.
No clutch to burn up, actual FNR transmission or gears.
Probably using an outboard prop, thus the crazy acceleration.
Quiet.
Cons:
Not crazy about that mass of wires and hoses dangling about to get snagged on every tree that you pass.
Where is the closed loop cooling system? How will it hold up to very shallow water or no water?
He didn't run in any very shallow water. Hell my old Merc 40 could have done what he did.
All in all it does look very promising. As far as mud situations and low wate levels, it may require a different prop. But that would be the sweet thing. For long trips have an open water prop and when you hit the shallows, swap it out.
Tue Jul 19, 2016 4:33 am
Tue Jul 19, 2016 4:49 am
Would probably be great down here on a tunnel hull with a skeg running the length of the tunnel to push the grass down. Kinda the same principle as the Ultra Jack jackplate.
Tue Jul 19, 2016 5:18 am
Tue Jul 19, 2016 5:33 am
Think about it. This entire surface drive craze started with a few different designs and now everyone has their own idea of how to make them a little better. How about taking what they have an couple a 60, 75 or even a 90 hp block on it that will weigh less than the 35-37 lawnmower blocks we have now. Pretty sweet.
Tue Jul 19, 2016 5:39 am
Id buy one if the price was reasonable. I don't really need to go through straight mud. You learn what your rig could handle and use it for that.
Those stump hits look pretty brutal with the weight back like it is. I wonder how the gears hold up after all that abuse.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Tue Jul 19, 2016 5:50 am
Tue Jul 19, 2016 6:38 am
A lot of potential there. Yeah, it may need a different prop to run 100% mud. But there's plenty of places that motor would work as is. I'm thinking about weed-choked reservoirs and flooded timber bottoms.
Tue Jul 19, 2016 7:49 am
Very interesting wonder what it weighs if it's lighter than the current 35 motors and priced right things could get good, it would be very nice to have a quiet motor for being able to sneak around in the swamp
1754 excel F86 44HDR
Tue Jul 19, 2016 8:08 am
Tue Jul 19, 2016 8:43 am
Freedom Outboard proudly presents the versatile family of outboard motors – www.freedom-outbaord.com email – freedomoutboard@yahoo.com Phone - 315-481-6520
Features
- 4 stroke liquid cooled Four Stroke Marine engine.
- 6000 rpm engine. Designed to run 6000 rpm by the designer and manufacturer. Not a heavily modified 3600 rpm engine forced to perform at levels it cannot maintain over time.
- Below surface exhaust at low speed. Never get burned by the exhaust again.
- Custom 5.5inch floating jack plate allows the motor to run flawlessly in deep or shallow water, mud or weeds. Even over logs and other sunken debris. Patent pending
- Closed loop cooling system ensures that the motor is always operating at the ideal running temp even in heavy weeds and mud. Patent pending
- A new bolt on lower unit extension and protection kit enables shallow water, mud, sunken debris, and weed performance like a mud motor. Patent pending
- Fully enclosed engine cover means no worries about freeze up of throttle cables or passing tree limbs pulling at wires. Best of all no chance of getting burned if you accidently touch the motor.
- A center long handle tiller is available with all controls mounted on the tiller arm.
- For those that prefer all controls can also be mounted remote to the grab handle as well leaving the tiller handle free of concern in the debris when you running in the timber.
- Adjustable anti- torque tab. This aids in countering the felt torque steer in shallow water mode.
- Available in 40 & 60 horse power.
Tue Jul 19, 2016 8:52 am
1754 With Level 3 GTR
Tue Jul 19, 2016 8:54 am
Got some info on it. The closed loop system uses a radiator which doubles as a seat. The "box" as I was told measures 15" x 15" x 18". Which is almost the same size as my side seat. Now given those dimensions:
15x15x18 = 4050 cubic inches = 17.5 gallons
If water is used, a gallon of water is 8.345 lbs
If antifreeze is used, an un diluted gallon of 100% antifreeze is 9.33 lbs
So say 50/50 which most use and split the difference at 9 lbs.
That "box" will weigh 157.5 lbs PLUS the hoses that is used so just say 158 lbs.
that's a lot of weight, but if the horsepower can account for it, then they may be on to something.
Tue Jul 19, 2016 8:56 am
$10,450 for the 40hp. Also available in 60 Hp according to wildfowl gear issue
1854 Prodigy DPE Level 3 HDR
Tue Jul 19, 2016 10:03 am
Id like to test one with a 100+ hp merc on my rig
Tue Jul 19, 2016 12:56 pm
Tue Jul 19, 2016 1:57 pm
That concept would be great for green tree timber
HOTSAUCE170 wrote:
Tue Jul 19, 2016 7:35 pm
Price is higher than a hippy on an airplane tho
Tue Jul 19, 2016 7:59 pm
^^^ got that right. It better exceed some expectations for that $$.
Tue Jul 19, 2016 8:14 pm
A modded GTR will be in the 11k range
Tue Jul 19, 2016 8:32 pm
I would probably be willing to give a 90 a try on my 18x54 cc if they made one in the 10-12k range. I don't think a 60 would perform much better than a modded GTR.
I also wonder who is building their power plant?
What do y'all think?
Tue Jul 19, 2016 8:51 pm
Very true...but a Gatortail is what I would consider to be a proven setup. I don't know if I'd be on board for 10.5k to guinea pig a motor. That said...whether its a surface drive, outboard, airboat or whatever a boat is just a hole in the water you throw your money into.
Tue Jul 19, 2016 8:52 pm
It's a mercury cowling, down to the logo on the front of it. Probably a licensing deal that they've worked out and why the cooler is the size it is.
Tue Jul 19, 2016 9:15 pm
I'd imagine there is a fan and other things inside the cooler not just a square box with water in it.
Wed Jul 20, 2016 6:18 am
Wed Jul 20, 2016 8:14 am
My gut is telling me that if mercury wasn't involved in this deal, if so they would be branding it, not allowing someone else to use there equipment in a manner other than it's intended use/ modifying there design..... LAWSUIT..Look at boss, its my understanding that they "Mercury" designed that system.. those are some big fellas, you don't poke at them. I think this guy would be better off designing a system that removes the outboard lower unit, and you would install a system he designed to act like a surface drive, on an outboard that WE the consumer would already own... he is just buying a damn 40, removing the merc stickers, slapping his goofy ass stuff on the mercuy lower, and reselling it as a freedom.. LMFAO :lol:
This has bad written all over it..
Just my $.02... but hey, I've been told that I am an educated idiot lol
This Message has been approved by Me.
Current rides:
Loaded dual gtr 18/60 stage one motors
Extreme hull 17/46 with 2016 25 Subaru
Wed Jul 20, 2016 10:45 am
Users browsing this forum: No registered users and 105 guests
