It is currently Sat May 10, 2025 4:35 am
[ 4 posts ] |
MB HD 4000 Grease inside air cooled out drive ftgs
Motostar929rr
I'm replacing the air cooling tube as it's kind of worn out between the engine cooling shroud and the outdrive which appears to cooling the clutch while in operation, I noticed when I took it apart that it there seem to be greased smeared on the inside of the barbed hose fittings I'm guessing this is to act as a bit of a filter to try and pick up any dust or dirt... can anybody confirm this? Thanks fellas.
Sent from my XT1585 using Tapatalk
Tue Oct 18, 2016 8:00 am |
lastchance
Joined: Wed Feb 09, 2011 1:56 pm Posts: 1646 Location: Chauvin
 Re: MB HD 4000 Grease inside air cooled out drive ftgs
Just guessing here but it could possibly be from the belt slinging grease from over greasing the bearings or smearing grease on the hose to install?
Tue Oct 18, 2016 10:13 pm |
Motostar929rr
Wed Oct 19, 2016 4:21 pm |
strobie22
Joined: Sun Nov 28, 2010 7:44 pm Posts: 122 Location: Western WI
I'd pop off the clutch cover and have a look your seal behind the gear on drive my be shot and is leaking grease into the belt box.
_________________ 1754 With Level 3 GTR
Thu Oct 20, 2016 7:50 am |
[ 4 posts ] |
Users browsing this forum: No registered users and 126 guests |
