It is currently Sat Dec 20, 2025 2:37 pm
Reply to topic  [ 4 posts ]
 Old GTR Trim (goes up, won't go down)
Post Old GTR Trim (goes up, won't go down)
Trim was jumpy going down on Saturday, and stopped going down completely on Sunday. I can hear the relay clicking when I engage the switch. Up trim still works fine. Any ideas on how to fix it?
Thanks!
Mon Aug 15, 2016 12:33 pm
Post Re: Old GTR Trim (goes up, won't go down)
Start with checking all your connections. Look for broken, frayed, damaged wires, etc. Also look for corrosion and any other signs of physical damage.
Oh, and the obligatory "use the search feature on this website" response.
Mon Aug 15, 2016 12:49 pm
Swap your relays and it will work more than likely the opposite direction. But you need to replace relays and look at the main terminal leaving each relay to the trim unit. That is one main corrosion spot.
Mon Aug 15, 2016 1:10 pm
Always keep spare relays, any little bit of moisture and they fry
Mon Aug 15, 2016 3:04 pm
