Loose skeg on a new motor
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=68272
Author:  Roostertail3 [ Fri Sep 16, 2016 7:34 pm ]
Post subject:  Loose skeg on a new motor
My skeg is pretty loose I can move it up and down about 1/4" and side to side 1/4+" each way. I have less than 20 hr on it. I can tighten the bolts no problem but should I try and claim this on warranty just incase the holes on the skeg got a little egg shaped from it being lose?
Author:  BlueShamu [ Fri Sep 16, 2016 9:34 pm ]
Post subject:  Re: Loose skeg on a new motor
Which motor?
Author:  Roostertail3 [ Sat Sep 17, 2016 3:56 am ]
37HDR
Author:  brycecheramie [ Sun Sep 18, 2016 8:11 am ]
Tighten the skeg!
Author:  rob_E [ Sun Sep 18, 2016 8:44 am ]
Nothing to claim (IMHO).
Things come loose on my rig all the time.
Mud motor maintenance 101.....Use the proper loctite on the bolts/ nuts, tighten it up, and check them after every trip out.
Author:  270Handiman [ Sun Sep 18, 2016 9:27 am ]
The skeg is welded to the outdrive. You talking about the support brace on top maybe?
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Author:  DmaxHunter [ Sun Sep 18, 2016 1:34 pm ]
The hdr skeg is bolted on the cav plate is welded on the hdr. The hd skeg is welded, just tighten the bolts.
Author:  Roostertail3 [ Mon Sep 19, 2016 12:52 pm ]
I tightend the bolts. Got about 1-1.5 rounds out of them which is a lot. I was more worried the holes would get slightly egg shaped and case tightening issues down the road. I didn't use lock tight but I will if/when they come loose again
Author:  BERNIE255 [ Mon Sep 19, 2016 1:26 pm ]
Its just a regular nut or a nylock?
