| MB HD 4000 Grease inside air cooled out drive ftgs http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=68668 |
| Author: | Motostar929rr [ Tue Oct 18, 2016 8:00 am ] |
| Post subject: | MB HD 4000 Grease inside air cooled out drive ftgs |
I'm replacing the air cooling tube as it's kind of worn out between the engine cooling shroud and the outdrive which appears to cooling the clutch while in operation, I noticed when I took it apart that it there seem to be greased smeared on the inside of the barbed hose fittings I'm guessing this is to act as a bit of a filter to try and pick up any dust or dirt... can anybody confirm this? Thanks fellas. Sent from my XT1585 using Tapatalk |
| Author: | lastchance [ Tue Oct 18, 2016 10:13 pm ] |
| Post subject: | Re: MB HD 4000 Grease inside air cooled out drive ftgs |
Just guessing here but it could possibly be from the belt slinging grease from over greasing the bearings or smearing grease on the hose to install? |
| Author: | Motostar929rr [ Wed Oct 19, 2016 4:21 pm ] |
| Author: | strobie22 [ Thu Oct 20, 2016 7:50 am ] |
I'd pop off the clutch cover and have a look your seal behind the gear on drive my be shot and is leaking grease into the belt box. |
