| BELT TENSION QUESTION http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=68711 |
| Author: | Gros'bec [ Sun Oct 23, 2016 1:00 pm ] |
| Post subject: | BELT TENSION QUESTION |
BELT TENSION QUESTION: I put a new belt on and tensioned it to 20lbs since that's the requirement on Mudbuddy motors. I ran it on the water for for about 20 mins. Now the belt has stretched a little and tension is at 15 lbs. The question is, do I now just retention it to 16lbs and keep it there or should I go a little tighter since it's still new? |
| Author: | Russ [ Sun Oct 23, 2016 5:17 pm ] |
| Post subject: | Re: BELT TENSION QUESTION |
Run it. When it drops below 13, tighten it to 16, check it for a couple hours, then you should be good to go. |
| Author: | Gros'bec [ Sun Oct 23, 2016 6:55 pm ] |
Got it Russ thanks. One more question. I put a new clutch on and used red Loctite and torque the clutch bolt to 55 foot lbs. Is that good or should I go a little less? I saw gator Trax video where they recommended 55 foot pounds, but also saw some specs on here where someone said 50 ft pounds. It's a 2006 Mudbuddy. Not the new HDR model |
| Author: | Russ [ Sun Oct 23, 2016 9:44 pm ] |
55. |
| Author: | Gros'bec [ Sun Oct 23, 2016 10:27 pm ] |
Roger that |
| Author: | Namasuke [ Mon Oct 24, 2016 5:16 am ] |
Learn to follow |
| Author: | Gros'bec [ Mon Oct 24, 2016 4:00 pm ] |
