What size prop? DIY -ish Surface Drive
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=68775
Author:  rotten_1 [ Fri Oct 28, 2016 7:19 pm ]
Post subject:  What size prop? DIY -ish Surface Drive
After trolling on this fourm and scouring the DIY sections i decided to build a surface drive with parts and pieces.
First I found a 27" Mud Buddy lower, picked up a Predator 670 motor new, and crashed McMaster & Car.
So... after fabricating a housing for the MB lower and started fabricating a transom mount, the last piece I need is a prop.
Specs are as followed:
Predator 670
Upper gear - 36 tooth 101.6mm
Lower Gear - 45 tooth 124.46mm
Gates 8m-1440-20 gt timing belt
MB 27" lower
What prop would optimize the gears and motor combo.
Boat is a Xpress 1650 with foam still in it. (will be removed after this duck season)
Thanks for all the information.
Author:  flint87 [ Fri Oct 28, 2016 8:47 pm ]
Post subject:  Re: What size prop? DIY -ish Surface Drive
Man why would you admit to trolling us and then ask for help. Maaaaaaaan.
Author:  rotten_1 [ Fri Oct 28, 2016 9:32 pm ]
crap, i'm out of the loop... NOT trolling: "make a deliberately offensive or provocative online posting with the aim of upsetting someone or eliciting an angry response from them."
I meant "cruising". or does that mean something else also?
Author:  SETx Longtail [ Sun Oct 30, 2016 8:02 pm ]
Not unless you like dudes too :lol:
